Question about Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 ARDF is not duplexing, why?
Duplexing is selected on the machine. The image to be copied is placed in the ARDF and the start button pressed. The image page goes through the ARDF and then a message appears that the ARDF has a jam. There is nothing in the ARDF but when you open it up and close it, the jam message clears. What can I do?
  • mammol Oct 11, 2008
    Great, thanks. Took a while to get the front off. The solenoid was stuck for what ever reason and once it was moved it freed up and works fine now.
  • mammol Feb 07, 2009
    It was a stuck solenoid.
  • 24 Answers
Hi All,
try one sided copy through ARDF, and if its work, then check the solenoid which open the bridge for second side of copy.
Posted on Oct 05, 2008
  • 3 Answers
Is this a 2-sided original? If so, take off the front cover of the ARDF (1 screw on the top, 2 on the bottom) and look at the solenoid on the front. It controls a gate that redirects the original for a second pass through the feeder, if the spring has popped off the solenoid the gate doesn't move and the paper comes out underneath the feeder tray and displays a jam condition. Pop it back on and you should be fine.
Posted on Oct 04, 2008
  • 58 Answers
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Posted on Oct 01, 2008
I would like to copy a 2 sised doucment as a 2 sided document
Not sure that model has duplexing - according to this site http://www.digitalsystemcopiers.com/Ricoh_Aficio_1013Fspecs.html duplexing is an upgrade.
here is the link http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio1013f.pdf to the manual
If a duplexing unit was added, you will have to refer to those instructions, if not then you will have to copy it one side at a time feeding the paper manually and flipping it manually.
Apr 08, 2014 | Ricoh Aficio 1013F Copier
MY Ricoh Aficio 2550 Printer I use it via IP in windows 7 and can't print Duplex Unit it said. Duplex :(Something conflict I can't Remember) Duplex: Unit not install
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
My sort buttons and button to copy from one sided to 2 sided disappeared. I tried to reboot the HDD and it says failed. Do I need to replace the copier??
hello mate. to select the sort options and duplex copy you have to select from machine operation. email me on ronils_singh@yahoo.com.au. i will guide you
Sep 24, 2010 | Ricoh Aficio 1035 Copier
I cannot make more than one copy when I place the original on the glass of the Ricoh aficio mp3500 copier
To make multiple copies, put your original on the glass, press the number key for the number of copies you want, and hit the green Start button. If you have Sort, Stack, Staple, or Duplex selected (or if they are selected by default), you'll have to press # to tell the machine that you don't want to copy other originals as well.
Jun 01, 2010 | Ricoh Aficio MP1600SPF Copier
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh aficio 1045 jams on duplexing
there could be multiple reasons for it to be jaming on duplex, just depends where in duplex it jams. most common for the age of the copier rubber rollers in duplex getting dirty or hard. like swan34 said try some type of rubber cleaner.
Feb 07, 2010 | Ricoh Aficio 1035 Copier
Aficio 1035 ARDF cannot pick papers most likely when they are over 4 sheets
Clean the takeup roller and feed belt with a damp rad (water). If that doesn't help, you man need to replace the roller, belt, seperator belt and possibly the sep roller torque limiter.
Sep 24, 2009 | Ricoh Aficio 1035 Copier
Installed XP printer driver for Ricoh CL7000 5c
during the installation you have to select this option, by default the duplex option is not selected. Uninstall the software, restart your pc and install the software again, and select the duplexing option. I hope this helps
Sep 03, 2009 | Ricoh Aficio CL7000 Laser Printer
Back to back not working
Do you mean your duplex unit is not working on the right side of copier?If so, check your door interlock switch where the duplex unit closes up against the copier.If it is bent or not making contact the oper. panel will not let you select duplex.
Feb 05, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 2035G Duplex issue
When you open the whole duplex unit you will see a very small metal tab with a screw, on the top right side on the machine. This activates the switch on the duplex unit.
Or with the duplex unit open you will se a small rectangle hole inside a switch, put a piece of paper or something to activate it, might got stuck.
This problem is very common on this machines.
Nov 18, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 Copier Logo
239 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
