Vcr recorda blank when digital tv is put on standby.
Philips dvdr/vcr combo brand new. problem with vcr recording. when taping a program from the tv it records blank after the tv is put on standby. dont want to leave the tv on while Im out ....
    Sergeant:
  • 196 Answers
This is because you are recording a direct connection (what is on the screen is recorded) that is an option with some equipment.. unfortunately this means if there is nothing on the screen well you get nothing..
You need to record from the machines own built in tuner dont use direct record.. a vcr/pvr/dvdr after all remember is like a tv without a screen that can record it has its own channels to do this
Posted on Sep 30, 2008
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
I record a DVD from VCR tape and try to play on another device
In my research, I learned about finalizing the DVD, which was a new concept to me. I looked that process up in the manual and it did the trick.
Nov 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
TV VCr Combo
The transport is now out of alignment, or broken. Seek professional service..
Oct 24, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Proper connections of my new Sylvania Model ZV420SL8 DVD /VCR recorder playback unit
Connect it to your TV set or cable box, just like you would a regular VCR. Then put a blank disc or tape in to record from either the DVD drive or the VCR drive. There should be an easy dubbing button to record from VCR to DVD. (I don't have this particular machine; I have two other brands of combo recorders, and I use them both like I would a regular VCR. This one shouldn't be any different.)
Nov 08, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
