Question about Acer Aspire L100 PC Desktop
L100 overheating You say you have a solution for the Acer Aspire L100 overheating problem. Don't tease us -- what is it?
  • cricket786 Oct 09, 2008
    my acer aspire l100 just freezes the screen and fan seems as if its stop working and the tower just gets so hot. i then turn it off from the mains and let it cool down for about an hour then switch it on and it works again till it overheats again..then i have the same problem again..please can u email me possible ways of fixing this problem to nahim.abis@ntlworld.com thanks very much..
  • kwhincop Dec 22, 2008
    yep, sounds like you just described my computer. Very noisy whirring fan which suddenly stops, screen freezes and/or spontaneous shut down.
    It is out of warranty anyway, so I opened up the back to get rid of excess dust, of which there was lots, but it still shut down today so may need a more advanced solution!
    Problem Solver:
  • 4 Answers
Replace the thermal grease. It only costs about 10 bucks. The thermal grease they use in these systems is cheap stuff. After I replaced it my system is quiet, no loud fan noises and my system can actually stream videos now!
Posted on Apr 20, 2009
In most of the cases the cooling radiator inside the computer is full of dust, clean it as well as the fanblades and things will improve.
Try to find a place nothing is blocking the inlet on the back and the outlets on top and in the front, open the part which covers the usb and other connections on the front.
Posted on Mar 28, 2009
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
    Hi
    thank you for your query
    Please can you try the following
    1) go to www.devicedoctor.com
    2) Download and install the device doctor software
    3) Once installed open it up and click scan, it will then scan your PC for the best driver
    4) Download the driver (entitled VGA driver) and install
    5) Restart and see if this cured the issue
    Regards
    Shauqat
    Jun 02, 2010 | Acer Aspire L100 PC Desktop
    I have a Acer Aspire L100 and would like to restore to factory settings please help
    If you have lost the automatic restore then you need recovery CD to restore it. To download try this link:
    http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-L100-XP-Driver-CD-Recovery-Restore-Disk-115940.html
    Apr 11, 2010 | Acer Aspire L100 PC Desktop
    No desktop view
    The L100 series has a bad reputation for overheating. I worked on a friends and had to reseat the heatsink for the processor with new thremal paste to keep it running
    Jan 26, 2009 | Acer Aspire L100 PC Desktop
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Possible overheating problem for Acer Aspire mini L100
    I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
    In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
    Sep 26, 2008 | Acer Aspire L100 PC Desktop
    Unwanted System Shut Down
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} ok guys this is the problem i work for Acer and basically if you own an aspire L100 then you have to be prepared to modify your little bad boy because of acers poor design and a crappy little fan the anything inside the case feels like its on holiday in the tropics what you have to do is side mount 2 extra fans with separate 12v supplies and your system will never overheat or die on you if you have any questions on how to do this just email me :-) me
    Aug 10, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    450 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
