Question about JVC KD-S890 CD Player
Power shuts off after 5 seconds
I cant get my stereo to stay on for more that 5 sec. it turns on, shows the time then 5 seconds later turns off. I can load CD or eject one, but the unit turns off right away.
HELP!
    President:
  • 1,263 Answers
What it's doing is sensing an overload of voltage this is an internal circuit problem. you can either have it repaired by an audio tech or replace it with a new one if the cost of repair is more than what the deck is worth. please rate this.. thanks
Posted on Sep 30, 2008
Mitsubishi Projection TV shuts off
A model number would help but many have a self check; when turn set on and power light (green?) comes on and a few seconds later off on the front of the set press and hold both the menu and input (label may be source) for at least 5 seconds and release both.
Power light will blink a two digit error code like 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
If you have unplugged the set it will always show the 1,2 above which is no error found, power it back and turn it on again, when fails do the check again.
let me know what error you find.
Dec 17, 2012 | Televison & Video
Please help!! i recently got a jvc kd-sc800 system off a buddy for my car, only problem is it doesnt turn on to be honest. every time i hit display it shows the display for like 5 seconds then seems to...
Please check if the connector of the faceplate and head unit don't have dirty or bended pins, these can produce false contacts between them and can produce fails as the one you have, if this is OK, maybe you have a bad faceplate or head unit.
Mar 18, 2011 | Car Audio & Video
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
I have a 95 Maxima I changed the fuel injectors and now the car wont start.  so i put the old injectors back and it still wont turn over,  It stay on for about 2 sec can anyone help me
I assume you bled off fuel pressure before you installed the injectors. Try this to pressurize the fuel system. Turn the key to "on" position and wait 5 seconds. AT same time, listen carefully for a buzz sound that means the fuel pump is running to pressurize the system. It will shut off after 5 seconds. Then, turn off the key and wait 30 seconds for the computer power relay to shut off. Then, turn the key to "on" again. Thsi will run the fuel pump for another 5 seconds. Repeat 5 times. Fuel system should be pressurized now.
If it doesn't start now, you may have done something while you were changing the injector. good luck
Jan 09, 2009 | 1987 Ford Tempo
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Sirius shots down after a sec...
make sure your device is fully charged, then attempt to turn on again. you may need to use the restore tool available thru the sirius website or mysirius studio.
Mar 22, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
JVC KD-S890 CD Player Logo
134 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
