Question about Photography
MINOLTA XG-1 & XG-9
I RECENTLY PURCHASED 2 MINOLTA 35MM'S.
AN XG-1 & XG-9. BOTH ARE USED. THE FILM ADVANCE LEVER WILL
NOT ADVANCE ON EITHER CAMERA. CAN YOU GIVE ME SOME
ADVICE?
  • Chuffman Dec 01, 2008
    Im having the same problem. So far I have found that it could be a capacitor but I guess the one in the XG9 doesnt normally go bad. Another option:
    If you own an XG 1, XG 2, XG 7, XG 9, XG-SE, XG-E, or XG-S that is notfunctioning properly (erratic light meter, miss-firing, no meteractivity) try the following to see if it helps. Remove the lens androtate the aperture control at the top of the lens mount all the way tothe right and then back again about 30 times. Also rotate the shutterspeed dial all the way around clockwise about 30 times. Most of thetime this will get the camera working properly again. These modelssuffer from bad contact surfaces that build up a patina, which in turnbreaks the signal, causing the camera to malfunction. Rotating theshutter speed dial and flipping the aperture lever helps to clean thesesurfaces and restore contact.
    Good Luck. Please post if you find an answer!
If everything lights in the camera when you test it ,it means the battery is alright,try this trick"Rotate the film advance connection at the bottom of your camera using a nickle (not the battery compartment) the one directly at the bottom of the shutter and should click if there's not you have some bigger problem.Good luck.
Posted on Apr 05, 2010
    Scholar:
  • 185 Answers
Traderholt,
the only real way to get the shutters to fire ( if not a mechanical problem ) is to take the top covers off and clean the contacts of all the sliding switches. both camera's are similar. check the flex circuit on top of the prism to be sure there is no broken circuits from impact damage not visible from the top cover .clean the battery covers and contacts. now the led's should light and the shutters fire. if the shutters don't fire then it's a component part on the flex circuit or mechanical failure. there are no new parts available for these models.
Posted on Dec 13, 2008
Film advance is loose and will not take a photo. can i fix this?
As ever, with mechanical cameras, DIY methods MAY work, if you have experience of this activity. A safer bet is to take it to a repair facility as it is, rather than a box of bits where you have tried and failed ! May be expensive, and not financially viable.
Jan 04, 2016 | Konica Minolta Vintage Minolta Xg-1 Camera...
The lever to advance the film doesn't go far enough to actually advance it!
This is a mechanical problem and must be sent off for repair.
Mar 16, 2010 | Minolta XG-A 35mm SLR Camera
Thhe camra will not advance the film or take a
I used minoltas for a number of years while going through college, though unfortunately this problem is fairly common- was a few years back but first time it happened to me i took the camera in for repair and if i recall theres a part that just breaks inside (number of years, cant remember the part).
It would have cost me round £60 to repair- bout 6 times the cost of the camera from ebay- I eventually just started buyin a new one from ebay every time the problem cropped up again.
I realise it may not be what you want to hear if your particularly fond of your camera, but the cost of replacing a part may very well be more than the camera is worth.
At the moment I have a minolta XG-M sittin on my shelf, hoping to track down some service manuals and see about taking it apart- I'll let you know if i find anything out, even with my fancy digital camera i still miss using the old 35mm.
Nov 04, 2009 | Minolta XG-A 35mm SLR Camera
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
How do I change film in my Minolta xg-a camera ?
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
Sep 30, 2009 | Minolta XG-A 35mm SLR Camera
Blank Film Developing
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Minolta XG-1 Film Camera View Finder has Door Seal Foam stuck in it.
jrbw123,
the top cover must be removed and the flex circuit on top of the prism must also be removed. then remove the prism to access the fresnel lens. the lens is extremely fragile and very difficult to clean.i would try to replace it with a good used one if possible. unless your a intricate instrument repair person i would let a camera repair person do this.
Nov 05, 2007 | Olympus Stylus Zoom 140 35mm Point and...
Photography Logo
1,105 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
