Question about Dell Dimension 4300 PC Desktop
Can"T connect to the internet
Network adapters not showing on device manager, & a yellow ? next to ethernet controller
  • scoe49 Sep 30, 2008
    Thxs very much
    Sergeant:
  • 268 Answers
Sounds like you need the driver for your network device ( driver is the software that allows your computer to communicate with your hardware)
You can download the driver here: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R35845&SystemID=DIM_PNT_P4_4300&servicetag=&os=WW1&osl=en&deviceid=2369&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=40109
Somply download it and launch the download , it will setup and configure it for you. That should get you up and running!
Posted on Sep 30, 2008
Internet both WLAN and ethernet
You will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a Red
X or a yellow Exclamation or Question mark !?
you will need to update or install the driver or it could be firewalled.
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters could see a yellow question / exclamation mark? ! or a red X right click install drivers
You only need to do the following if you cant install the driver
Make sure you Ethernet/internet is enabled in biosRestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) usually the Delete or F2 key press and hold that key to enter bios using arrow keys scroll to intergrated peripherals.
Look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press ENTER make sure its enabled
wifi
Most new laptops are equipped with all the components necessary to go online wirelessly to account for the increasing popularity of Wi-Fi Internet.
If you find that you are not able to connect to any wireless networks on a laptop, take a few basic troubleshooting steps on your own before having the laptop serviced.
In all likelihood, you will be able to restore your laptop's wireless functionality and be browsing Wi-Fi Internet in no time.
Enable the wireless card by pressing the radio button, typically located near the top of the keyboard.
Press the radio button until a light illuminates indicating that your wireless card has been enabled and is ready to go online wirelessly.
Test your connectivity once again; if there is still no wireless access, it is time to check for a possible issue with your wireless card.
Navigate to the computer's device manager by opening the "Start" menu and either clicking "Device Manager" from the "Control Panel" window or right-clicking "My Computer," clicking "Properties," and choosing "Device Manager" from the "Hardware" tab, depending on what version of operating system you use.
Look for the wireless card in the Device Manager by clicking the "+" next to "Network Adapters." If you see any item labeled "Wireless Card" or "Wireless Controller," check to see if it has a "?," "X," "!" placed over the name; if it does, you will need to update the software drivers for the wireless card. Contact the manufacturer of the computer for assistance.
Attempt to connect a wireless network other than your home network. Make sure you connect to a wireless network that you are legally allowed to use, such as a free public Wi-Fi hotspot, and that you are not illegally connecting to someone else's wireless network.
If you can connect to other Wi-Fi networks, the problem is likely isolated to your home network and you will need to troubleshoot that.
If you are still can't connect to any Wi-Fi networks after following the steps above, you may need to have the laptop serviced or have its wireless card replaced.
Mar 10, 2014 | Computers & Internet
I uninstalled the wireless network adapter ( accidentally ), How can I install the adapter again. my OS back-ups won't work. I downloaded the drivers and ran, still no adapter in Device...
Plug in the Ethernet cable to the PC, go to device manager via the control panel and your wireless network adaptor will show there (under other devices) with a yellow question mark next to it. Right click it and select update divers.
Oct 05, 2017 | Computers & Internet
Unable to conect to internet this is on going problem
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
or you could click start control panel admiistation tools computer management device manager look for network adapters it might have a red X or yellow question exclamation ? ! mark if you see either of these right click to update driver if your computer came with a motherboard disk the drivers could be on it
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jul 21, 2011 | Computers & Internet
I re formatted hardrive. reinstalled O/S. cannot connect to internet. device manager shows yellow question mark over ethernet controller, multimedia audio controller, video controller. has error message:...
What kind of computer do you have? The trick here is first to get the computer on the internet by finding out what kind of network card is installed on a internet connected computer do one of the following
1> If its a dell go to http://www.dell.com/support and click on download drivers enter your service tag number Download the network driver to a flash drive and install Connect to the internet and repeat the above process to install the other drivers.
Most manufacture websites will have a download page for the drivers but you can also google the make model and operating system drivers for example google acer aspire 1000 xp network driver.
if you post your make model and operating system I can help you better.
Aug 04, 2010 | Dell Ethernet Card Network Adapter
Internet not connecting?
May be your Ethernet Controller is not installed. To confirm this, go to "Control Panel", click "System" from there look out for "Device Manager", click it, check "Network Adapter" to confirm if your Ethernet controller is installed or not. You might also see "Others", in the "Device manager" where you will find only components of your Laptop that are not installed with a yellow exclamation mark.
If you have confirmed that your network adapter is not installed, then you wil have to install the drivers.
Please give me feedback.
Take care.
Nov 17, 2009 | Dell Inspiron 1420 Laptop
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
Cannot connet ot interner
check the driver of your network controller, go to device manager, to access this, right click my computer then click device manager tab then find network controller then click + sign preceeding of that. if you notice that there is yellow question mark of the network, you need to install driver so that you cant connect to internet
Oct 12, 2009 | Computers & Internet
Need driver for airlink 802.11g ethernet controller.
1. Go here: http://www.airlinkplus.com/downloads.htm2. Click on the device you have3. Download and install the Windows XP drivers
Regards,AbdielPC repair fort lauderdale
Apr 12, 2009 | Belkin (F5D7010) 802.11a, 802.11g/b...
Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
I had to reinstall windows xp. Now I cannot connect to the internet.
Make sure the driver of the Ethernet Card on your computer is installed. You check it under Device Manager
Right-click My Computer > Properties > Hardware Tab > Device Manager > Network Adapters (click the +). If you see Other Devices with yellow exclamations like Ethernet Controller, that's it. You need to run the Motherboard CD to automatically install the ethernet driver.
Jul 24, 2008 | Computers & Internet
Dell Dimension 4300 PC Desktop Logo
85 people viewed this question
Alun Cox
