Question about Whirlpool LEQ8000JQ Electric Dryer
My dryer doesnt heat.
Everything works ok only it doesn heat you dont hear the heater on or something, gas line its ok, its a whirpool mod LGR8648PWO i wonder wats the problem? can you help me?
Thanks.
Antonio.
  • Landeros71 Oct 03, 2008
    i replace both, bacause one coil was blown but didnt work :( there is no flame on the burner the ignitor works fine also the coils but no gas. and external gas line is ok.
    Sergeant:
  • 409 Answers
check the ignitor and the coils on the burner assy.
Posted on Sep 30, 2008
I have a whirlpool LGR8648pwo. Runs not heat and timer doesnt move. I found a 4 prong sensor in the back of the unit. 2 prongs have continuity and the other 2 dont. Is that bad.
If no heat at all i suspect this part HERE. This is the fuse. It kills power to the gas assembly if junk gets into the filter housing and cause an overheat condition. On electric models this same fuse kills the whole dryer. On gas models it just kills the gas. If that is good the next thing to check is the flame detection sensor mounted out side of the burner chamber. It's job is to power up the ignitor. If it is open no power can get to the ignitor. If it is good then the next thing to check is the ignitor. If the ignitor is good AND you are getting power from that control klixon you mentioned with the 4 wires on it AND you can get a little heat at first but then none at all them coils need to be replaced. Here is my home video:
Dec 09, 2012 | Whirlpool LGR8648 Gas Dryer
We have a Whirpool AWZ 2303 that only blows cold air & the heater element looks OK - will it definatley need a new heter element or could it be something else?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Dryers
Cloths dryer Whirpool does not heat the heating element is OK
heatman101
Aug 29, 2011 | Dryers
No heat, everything else is fine whirpool module R6X3519PQ0 Type: D433 Thank you Bert
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 11, 2010 | Whirlpool Dryers
Mod dpsb613ed2ww bought a used dryer and it does the same as my old dryer, it does not hear everything else workd
heatman101
Aug 30, 2010 | GE Dryers
Im at a complete loss with my dryer. It runs but doesnt heat
Check the 230v very carefully You may be hooking it up even with new wire just like the old. You have to have across the line 230
not just 230. Sounds like you need to have an electrician to check
230 across the line at the wall.
Let me know.
Leo Ponder
imufo2@sbcglobal
Jul 22, 2010 | Whirlpool GEW9250 Electric Dryer
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Whirpool Mod WGD5300SQ0
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Jul 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Just another damb heating problem
on gas dryers there are two coils on the burner assy. (small black cylinder with two wire haness) one opens initially to allow gas for ignition after that the flame sensor will allow the secondary to open for continuous flame i suggest replacing them both
Jan 18, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
166 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
