Question about Pentax Cameras
Optio L40 lens won't stay out when turned on, then turns itself off
Hi
I have an Optio L40 - it worked fine one evening and then the next day I went to review the pictures and it wouldn't work properly. When I press the on/off button, the lens comes out as usual, but then makes a really horrible sound like it's stuck, then tries focussing, then goes in and out and then repeats the process making the same noise again and then turns itself off. I have tried several times since in the hope that one time I try it will actually work! The battery is fully charged.
Hope you can help and thanks in advance for your time
Sarah
t00nz
  • 4738 Answers
SOURCE: olympus fe170 lens stuck
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE: Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: Lens stuck
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Posted on Mar 02, 2008
SOURCE: lens stuck
THIS CAMERA IS **** WHO EVER MADE I didnt even drop mine n the lens is stuck n i payed heaps for it n accpect it to last long ive only got it a month ago :(
Posted on Mar 27, 2008
The Machine
  • 788 Answers
SOURCE: I have a Krup Orchestro
When you ran the cleaning cycle did you use the Krups cleaning tabs?
Posted on May 21, 2008
Lenses are out/won't turn on/off
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
Apr 13, 2010 | Pentax Optio P70 Digital Camera
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
Sep 17, 2009 | Pentax Optio S10 Digital Camera
My Pentax A30 will not stay switched on
Try drying the camera out - mine did this after it got wet. After a few days it still didn't work so I put it in front of a fan heater [not too close] for half an hour and after that it was fine.
Feb 12, 2009 | Pentax Optio A30 Digital Camera
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
Optio M40 turns itself off and the lens wont retract into the camera when off
yes me too! one side of my lens hit the ground and is stuck. it wont come out and my camera also automatically turns itself off once i try to start it. i think you shoudl go get your lens fixed...mines stuck and wont go in or come out
Apr 28, 2008 | Pentax Optio M40 Digital Camera
Pentax optio m20 .. on-off immdly
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 25, 2008 | Pentax Optio M20 Digital Camera
I think my camera's stuck
I had the same problem the lens wouldn't retract and it would only stay on long enough for the logo to show...I found out my lens changed slightly cooked to oneside I gently moved the lens to center and now it works great...look at the lens and see if this helps
May 16, 2007 | Pentax Optio M10 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Cannot turn on my Optio S
When I have that problem I replace the bettery with my spare and I recharge the battery that came out. Works every time. Maybe your battery is worn out and not holding it's charge properly.
Aug 30, 2005 | Pentax Optio S Digital Camera
Cameras Logo
70 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
