Mitsubishi Model VS-5043 Horizontal tearing or flagging at the top of picture down 2-3 inches. I do have the service schematic on this set, thanks for any wags on this set, cubsfan1953@yahoo.com cubby
You wanna charge me to join your site, I'm a Technician of over 30 years and just wanted to see if any other tech had ran into this, so if you want my fixes you can join my site. cubbiesdata.com
have a good day.
Cubby
Posted on Oct 01, 2008
Vs 5043 mitsubishi no picture
Dear dc_rock,
These the most common failures for this TV Model VS-5043- VZ3:
1. Check base bias Voltage of Q217, for 0 VDC (BIASED OFF) if .7 VDC (BIASED ON) check C268 (22 UFD 50 V) off C OF Q215 V-Protector on the SIGNAL PCB.
2. Vertical Beam Blanking Active, check PIN 4 of IC401 for 3 VDC. If missing check IC202 (5V REG) PART # 266P932010, on The SIGNAL PCB.
3. Check Pin 6 of IC200 for 9 VDC if low or missing check IC203 Part#
270P210010 on the SIGNAL PCB.
Thanks for using FIXYA, big IRISH.
Dec 25, 2009 | Mitsubishi Televison & Video
Mitsubishi has a problem
Ur Horizontal/Vertical ic stablizer is dead or it supporting componnents.90% is ur IC.
Aug 25, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Video
What kind of input are you using
Nov 05, 2017 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Tv repair
try resoldering the vertical output IC and the horizontal output transistor. It sounds solder related
Mar 25, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-585R
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Dec 21, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Black horizontal lines on mitsubishi VS-5043
Is the noise in all inputs (line, tumer) ? If it is in the tuner alone, check the coax lug to see if you knocked it loose. This could be the problem. Check you picture with a DVD player on the Video input. Let me know what you find.
Jul 03, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Jan 06, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
