Question about Nikonos V 35mm Point and Shoot Camera
Nikonos V underwater camera w/ strobe
I have a Nikonos V underwater camera. The problem is with the strobe. The strobe wont activate. When I take a picture, the camera clicks and then like 3 seconds later it clicks again louder. The strobe never flashes. I thought it might be the cable and replaced it for 100.00 but it still does the same thing. please help!
  • 667 Answers
It sounds like you'll need professional service. Even slight moisture damage can foul up the shutter or the wiring that runs from the camera to the inside of the connection port. You can remove the access plate (4 screws) above the film chamber. The 5 wires below the rewind knob (blue,yellow,purple,green,black) lead to that connector. I would also check the shutter functions on M90. See if it opens.
Posted on Oct 02, 2008
Which slave-unit to use for firing my Nikonos SB 103 underwater flash
Another SB103 they work together you have to set one to slave
The other in command mode
Apr 17, 2014 | Nikonos SB-105 UW TTL Speedlight Set 11202...
SB105 connector broken
Yes you are right when broken it does not work properly
Feb 10, 2014 | Nikon 2 Sets Of Nikonos Sb 105 Strobes
I have purchased an Ikelite AF 35 strobe to use with my Sony DSC-TX1 camera and underwater housing. Even with the strobe set to the lowest setting, the photos I take with the camera set to 'housing on' are...
akdenny, have an af35 myself and know from experience the issue is very likely to be the way you have the block out for the cameras flash. if you block it by having the tape inside the housing it confuses the af35 to fire at a higher setting. from what i can gather it senses the strength of the camera flash and adjusts. I get the best results with the blockout on the camera supplied diffuser, stops the flash camera going forward and gives plenty of light to get the af35 to fire right. to blockout i just use some black tape , fabric tape seems to stick well.
you will still need to set the auto level setting.
hope it works out, i find it a great flash. and the guys at ikelite very very helpful.
Dec 28, 2010 | Ikelite 4035 Left Hand AF35 Auto flash kit...
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Question on SnapSights waterproof camera
The SnapSights SS03 is a non waterproof camera supplied with 200 ISO film so you clearly have the SS01 model for 800 ISO. Both cameras have fixed aperture and shutter speed and rely on the wide exposure latitude of print film. 100 ISO is ideal if you have a camera with a wider aperture than yours, but if you use it then photos will be three stops underexposed; you'd possibly get away with this on land but underwater shots typically have more shadows than highlights and you'd lose a lot of photographic detail. By using 800 ISO the camera will produce photos which are noticeably grainy and with high contrast demonstrated by less detail in shadow areas and overexposed highlights, but for most purposes the photos will be acceptable and far better than none at all.
Colour negative film has a wide exposure latitude so you may wish to experiment with using 400 ISO or even 200 ISO. 400 will be one stop underexposed, but the printing stage can compensate to produce shots which are less grainy with better shadow details but which will lack some highlight detail. This can be partially compensated for if you tell the processing lab to "push process" your film at 800 ISO, but this will usually cost extra and for just one stop under I wouldn't bother, 200 ISO is really stretching it though and you may find that results are unacceptable unless you push process. Ultimately, it all depends upon how dark and how deep you go, but at much below 1,5m everything gets a strong blue colour cast anyway unless you use a powerful underwater strobe light mounted away from the lens axis.
Basically your camera is designed just to give you a taste of underwater photography and is very limited in what it can achieve. Even with a good specialist 35mm underwater camera such as the Sea & Sea MotorMarine II I usually find that I only have one or two usable shots on a 36 exposure roll, so if you do get the underwater photography bug then invest in a decent quality underwater digital model which accepts a proper external strobe lamp. The ratio of failed photos is similar, but at least you can review and delete them immediately without expense.
Jan 09, 2010 | SnapSights Intova Snap Sights SS03 Film...
Nikonos v with Nikon 15mm f/2.8N UW-Nikkor IC... > for sale
Good lord! That's a NICE underwater system you've got. What type of help are you asking for? Just from your equipment list, if everything is in good condition, you've got at least 1500.00 worth of stuff! A new 15mm sells for $2,240, the camera, new, $750.00, eiklite flash system is up there, the extra close up gear ain't cheap either! And a pelican case--well, if yer gonna go snorkeling or scuba, you're all set! The 28mm can be used for land lubbing or underwater. To properly prepare the camera, the most important thing is to check the condition of the o-ring around the film door. If any doubt, replace it!! The same applies with any other o-ring seal. *Properly* greased, an O-ring in good condition simply looks wet. Use a good quality, pure, silicone grease all over the ring and don't blob it on--It can be purchased just about anywhere. Check the o-rings on all the other equipment--same rule applies. Salt water damage is u-g-l-y. Before opening up the camera after being in salt water, rinse all equipment in fresh water and dry completely. Don't detach any cords or lenses until all are rinsed and dry! (When cameras and salt water come together improperly, think horror movie acid bath results--and you won't be far off) I used 36-picture rolls of film so I wouldn't have to open the cam as much. Heh, in the excitement of photoing fish, yer gonna burn some film.Hope I assisted you!---Rick
Oct 02, 2009 | Nikon 15mm f/2.8N UW-Nikkor IC Lens
Do you also cover the IV-A?
open the back cover and fire the shutter a few times towards light. the shutter should open completely with no hesitation. check to see if there is oil on the blades. if so the camera must be cleaned.
if no oil on the blades then the shutter magnets are at fault and it will have to be repaired. you may need to hold the counter lever in to fire the shutter with back opened.
Oct 06, 2008 | Nikonos V 35mm Point and Shoot Camera
This lens is intended for a Nikon underwater camera which are branded as Nikonos cameras. These cameras are underwater 35mm cameras and this lens is and extreme wide angle lens to capture underwater scenic’s. This lens is rather expensive and of very high quality. I hope this helps!
Go Ahead. Use Us.
Jul 17, 2008 | Nikon 15mm f/2.8N UW-Nikkor IC Lens
Nikonos V 35mm Point and Shoot Camera Logo
107 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
