Question about Thomson Televison & Video
Thomson 42WM03L TV shows no picture. There are some color-fragments on the display. Audio is ok. Voltage on the boards seems to be ok.
  • Elbundee Sep 30, 2008
    Has anybody a shematic or manual?
  • Elbundee Oct 02, 2008
    Sorry, i don't know where to find the IF-Transformer. On which Board is it? Can you tell me more exactly, as you know I hove no shematic or manual.
    Thank you
    Champion:
  • 252 Answers
Try to adjust the IF transformer (VCO)
Posted on Oct 01, 2008
No picture
It seems that the TV displays only a blue screen, and no video at all. There are two possibilities for this fault. As far as audio is OK, the man board have no fault, Check the LVDS cable that connects to display panel to T'con board for any loose contacts. If it is found OK, either T'Con board or display panel itself is faulty. If you wish to get more details, http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option.
Jun 30, 2013 | Televison & Video
Thomson tv
Check its audio setting at its sound setting menu first. If audio is muted, there will be no sound output. Check the speakers. If they are too OK, check and replace damaged component/s at its audio output stage circuit. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 08, 2013 | Thomson 29DM400 29" TV
Hi, I have a samsung samtron 55V 15 inch monitor. The problem is it is not displaying the actual colors. The red color appears as a greenish/bluish shade. Ex: The Windows Start button is showing as light...
You have to check for dry soldering in the base board of you mointor. The base board is on which is attached to the picture tube neck. In most cases there will be dry soldering in the pins of cathode diver ic in that base board. It will be difficult find out which pin have the dry soldering. Do on thing resolder all the pins of that ic. This ic cotrols the three cathodes of picture tube (red, blue, and geen) is any one did not get the correct drive that color will fail to display. In your case the red cathode is not getting the drive voltage. Thats why it shows only gree and blue. This is a reular complait for crt monitors.
ok
Jul 17, 2011 | SAMTRON 55V 15" CRT Monitor
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Samsung PCL541R 54" Rear Projection...
Thomson AW3717651 TV has sound but no picture
It could be one out of the two problems..
1. The plasma panel or the components which supply electricity to the plasma in the panel have packed up.
2. The video processing unit in the set has gone.
Also the y-sus video board which is a common problem with plasma sets.
Call a competent person to remove the back panel-remove the board and power the set up-if it is this board the set will display the top half of the picture only-when replaced no picture will be displayed.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Thomson Televison & Video
My tv only shows the blue and green colors. I opened up the back and the red lens is not on????? What do I do?????
Check if the menu display shows the same. If the same, then check CRT, CRT board, G2 voltage for around 200V. If menu display ok, check red component cable. :)
Dec 29, 2009 | Sony KP-61V90 61" Rear Projection...
Thomson 27LCDB03B
If all the voltages measure normal, the failure could be in the LCD's inverter board. I've checked the schematic and it seems like the 16 volts could be a bit higher, check the electrolytic capacitors filtering the voltage for the inverter board.
Click here to download the service manual.
Good Luck.
Sep 12, 2008 | RCA HD50LPW175 50" HDTV
Sony FWD50PX2 screen displays color noise
Hello Zirben:
You will ned to have your Tv looked at by a repair shop there seems to be a problem with the small singal board.
The Slash
Jun 11, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
224 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
