Question about Frigidaire GLTF2940ES Front Load Washer
E20 on Frigidaire front loader
Thank you SO much for your solution dated June 2008. I followed your advice and found one of my kids socks in the drainage area under neath. Not quite sure how it got there - but its out and now my washer seems to be working just fine. Thank you SO very much!!! As a stay at home mom I appreciate your advice to save on a service call!
  • Anonymous Nov 21, 2008
    My washer will fill up with water and wash. But then on rinse it gives me a e20 and there is water still in the tub. Now I noticed that my fabric softner is not all gone in my bin for fabric softner. I can put on spin and it will drain out water for me. I also on normal wash it says 48 mins. This seems to take a hour to wash is that normal that it would take longer thant top load washers?
    help.......
  • mswky2000 Jan 12, 2009
    i have a ltf2940e and it is giving me the error e20. it fills and washes but when it gets ready to drain it dont. you can even put it on drain and spin and it does nothing. acts like it wants to pull the water out but it doesnt. i dont see where i can take the front panel off. can you please help. i'm not too good at taking things apart....
    Sergeant:
  • 276 Answers
Check out the washer drainage area regularly to avoid this problems.and also clean the washer regulary in a week to give a long life to the machine.
thanks.
Posted on Nov 18, 2008
What city or town is this 213 area code located in?
North American area code 213 is a California telephone area code which was one of California's original three area codes created in October 1947. It has historically been associated with Southern California and Los Angeles.
Originally, it stretched from the southern portion of the Central Valley to the Mexican border. Due to California's burgeoning population, however, it has been subdivided numerous times. It now contains only downtown Los Angeles and its immediate environs, and is completely surrounded by area code 323. The subdivisions to date have been:
Mar 29, 2011 | Computers & Internet
Tip
Four socks! Four 2-year old child socks! That's what I found inside the drainage...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
I keep getting error message f 02 which is a drainage problem but there is no drainage problem??????
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4THUMBS rating is appreciated for answering your FREE question.
Sep 23, 2009 | Whirlpool Washing Machines
Mildew odour from Whirlpool Duet washer.
I've had this problem a couple of times over the years I've had this washer. What caused the odour in my machine was one (or more) of my kids' socks getting stuck in the machine. With the door open, gently reach in and bend the grey rubber door seal back and feel for clothes that have slipped between the drum and the rubber. If there's nothing there and it has been smelling bad for a while, then it's likely that the socks have been sucked into the drain. To clear this without paying a $150 service charge (I did that the first time and watched him fix it in 10 minutes), you'll need to remove the bottom front plate of the washer (there are only three or four Torx -or star head- screws holding it on). Once that plate is off, you'll see a white plastic knob that is the cap of the drain trap. Unscrew the cap and a couple of cups of water will leak out so shove a couple of towels under it beforehand. You should find some long-lost now-rotting socks. The last time I had to do this, I found FOUR socks in there. This also contributes to the 'suds' error message as it prevents proper drainage. I've only had this problem with kids' socks, everything else is too big to get stuck, I guess. Maybe try a laundry bag for the smaller stuff.
Apr 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When we start our washer water runs out the detergent tray
I had the same problem about a week ago and found a sock had made it into the drainage area (between the drum and the rubber liner inside the door).  Just peel back the liner near the inside edge and inspect the area with a flashlight to see if anything is there.
Mar 17, 2009 | Kenmore HE2 Plus Front Load Washer
DATE DIFERANCE BETWEEN SELECTED COLOUMN
Are you trying to figure the difference in days between these dates and one single date (Dec. 31, 2008 for example)?
Whatever you're trying to do, here is the formula, assuming you're starting in A1:
Put the first date in the format Day-Month-Year in numbers (Sept. 3 is 03-09-2008)
Then put your other date in B1, in Day-Mo-Yr format (31-12-2008 for Dec. 31, 2008)
In C1 put B1-A1 and that will give you the number of days between those two dates.
Dec 27, 2008 | Microsoft Excel for PC
Oracle date problem
All dates are actually date-time fields - if you don't specify the time, Oracle defaults to midnight. To filter date-time specify the date-time string as a formatted field like this:
select count(*) from mytable where dttm > to_date('20080610181907','YYYYMMDDHH24MISS');
This is the date June 10, 2008 at 6:19:07 PM as an example.
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Need to cancell below order, since I understand that I can not get warranty on used washing machine
Ill be sure to cancel your order. Thank you
Just Kidding; youve somehow posted your request on an online fix-it forum please redirect your desire to cancel your order with appropriate website!
Apr 01, 2008 | Washing Machines
Intuitive washer
Lets clear this one up. There is not filter on a Smart Drive, Yon will need to removed the top deck of the machine, then the agitator, then the inner bowl. You will then be able to access the pump cover (front right hand side of outer bowl). Removed the screw retaining the cover, then remove the obstruction, it will probably be hair clips, bra underwires etc
Mar 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Frigidaire GLTF2940ES Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
