Question about HP Televison & Video
Our external DVD player was working - now it's not.The computer does't seem to reconize it. It is connected and the eject works but the drive dosn't show up in the computer icon
  • 1 more comment
  • Irene S Oct 06, 2008
    The icon for the external dvd does not show up in the My computer icon. We were using it & it was working fine but now it's not. The light comes on and the eject button works but the computer does not seem to reconize it. I don't know if someone accidently deleted something or what. The CD drive that is in the tower dosen't work either - same problem. PLEASE HELP
  • Irene S Oct 07, 2008
    The icon for the dvd dosen't show up in the My Computer icon anymore. The computer dosn't seem to reconize it. The last time I posted this guestion I was told to unistall it from the device manager and reboot. That didn't work. The message I get is this - Windows sucessfully loaded the device driver for this hardware but cannot find the hardware device. (code 41) Somebody PLEASE HELP ME!
  • Irene S Oct 08, 2008
    This is the 4'th Time I'm posting this guestion. Nothing has worked. Our external dvd was working. Now the dvd icon doesn't show up on the My Computer icon. The computer dosn't reconize it. The device manager gives this message - Windows sucessfully loaded the device driver for this hardware but cannot find the hardware device (code 41) The eject works and the little green light comes on but it dosen't work. The CD drive in the tower doesn't work either. Can anyone help me
  • HP Master
  • 4,338 Answers
Since both your internal and external drives are not working, I suspect something other than drivers or connections.
After reading all the solutions posted here, the only other thing I would suggest the you update your Virus program and run it in safe mode. Ther may be some trojan or Spy ware causing this problem.
Download CCleaner, this will remove Temp files,TIF's and cookies. Pest usually hide in these.
Also, you can try to restore the XP to an earlier date where the devices had been running ok.
start> all programs>accessories>system tools>system restore.
Joe
Posted on Oct 08, 2008
    President:
  • 2,712 Answers
Try this:
  1. Click the Start button
  2. Right click My Computer
  3. Select Manage from the resulting menu
  4. In the Computer Management window, select Device Manager
  5. In the right pane, click to expand IDE ATA/ATAPI controllers
  6. Identify your CD/DVD drive in the expanded menu and right click the appropriate drive
  7. Select Properties
  8. In the Properties windows, click the Advanced Settings tab
  9. In the Transfer Mode box that represents your CD/DVD drive (typically Device 1); open the dropdown menu and select PIO Only
  10. Click ok and exit all windows
If this does not resolve your issue, then you will need to go back using the above procedure and change the Device 1 in step #9 back to "DMA if available". Then, change Device 0 to "PIO Only" in the Transfer Mode box.
For reference, the Device 0 is the Primary IDE Channel and the Device 1 is the secondary IDE Channel.
After you change your settings, make sure you restart your system so that the computer recognizes the changes you have made. After you reboot, check the settings to make sure they are in effect. If they are, your device should now work properly.
Hope that works!
    Sergeant:
    Champion:
  • 435 Answers
Hi, Thanks for all information. Here are the solution given by microsoft for error # 41.
If the device was removed, uninstall the driver, connect the device, and then click Scan for hardware changes to reinstall the driver. • If the hardware was not removed, the driver files might be obsolete. In this case, update the driver from Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver. • If the device is a non-Plug and Play device, you may have to install a newer version of the driver. To install non-Plug and Play devices, use the Add Hardware wizard. Click Start, and then click Run. In the Open box, type hdwwiz.cpl.
But I personally feel that your Plug and Play has been disabled in your BIOS.
While the system boots, you should get an option to get into BIOS/ SETUP and asks you to press some key for it.
Get into BIOS/ SETUP, look for "plug and play devices" and enable it.
If it still doesnt work, try this player in another computer/ laptop and see if it works, if not the player is defective.
Posted on Oct 07, 2008
    Scholar:
  • 125 Answers
Hey Irene,
Code 41 is caused by bad device drivers, missing system files, wrong system settings or a corrupted registry files. I am pretty sure that the error is not temporary so i have the following website for you and what you have to to is download the Guided Help by Microsoft where the guide will help with(step by step) on solving your problem. Its really easy
http://support.microsoft.com/kb/314060
and just click on
Download Guided Help
I think for your case its a combination of the three symptoms that are affecting your External DVD Drive from functioning properly. Le me know how that turns out Irene and feel free to ask for any other concern or questions that you may have. Thanks for using FixYa.com.
  • HP Master
  • 6,487 Answers
Try to plug the drive on a different USB port, then run again the setup CD for the player and reboot the computer ...
Hope that helps...........
    Scholar:
  • 116 Answers
Try to eject the dvd from pc.and if the eject is working when you give a command from the pc that means the dvd is still detected by the computer properly.and if the eject command given from the pc does not eject the dvd then there is a loose wire in the dvd either on the hard disk to which it is connected or on the mother board.please remove the wires of the dvd by opening the cpu unit of the pc.DO IT AFTER YOU SHUT DOWN YOUR PC.DO NOT DO ANYTHING WHEN THE PC IS IN ON CONDITION.then reconnect all the wires and on the pc.it should work.
hope this helps you.......
please keep us updated if it gets solved.
Posted on Oct 06, 2008
  • mastermind10 Oct 07, 2008
    this will work for you 100% please try this.
    A driver was loaded but Windows cannot find the device. This happens when Windows does not detect a non-Plug and Play device.
    If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
    If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
    On the General Properties tab of the device, click Troubleshoot to start the troubleshooting wizard
    if this does not solve your problem.
    and this will definately work
    Re: CODE 41
    Anyway I have resolve the issue:
    To resolve this behavior, follow these steps:
    Start Registry Editor (Regedt32.exe).
    Locate the UpperFilters value under the following key in the registry:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    On the Edit menu, click Delete, and then click OK.
    Locate the LowerFilters value under the same key in the registry:
    please rate the solution if it helps you,
    Genius:
  • 3,422 Answers
Try connecting your drive to another USB port. Using one port all the time to connect and disconnect USB items a port can develop a range of files associated with configuring the USB connection. Some of these files might actually have been from your drive connected before, or some of these configurations could be from other USB items you connect to this port. Changing ports can often lead to an immediate good connection simply because ther are no conflicting configuration files. If this does not solve your problem, we can now entertain the next process to try.
: THIS IS A BIG ONE. This is the last thing to do. Before you try this process, please complete a full back up of your system. This is important as the next step can have side effects you did not entirely expect. AND Second, you might need your XP Install Disk (not in all cases). What this process is about is renewing all hardware/software configurations relating to USB connections.
Here is what you do:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
If these suggestions are implemented and you are still have connection difficulties with your computer, there are several other things to try. If you have another XP Computer you should try connecting your drive to another computer to see if the problem is a drive problem or not. If it still has this problem with the next computer, then the fault is with the drive
Posted on Sep 30, 2008
    Genius:
  • 1,550 Answers
You need to check whether the cable used to connect dvd player and computer is proper .
If it is proper try to disconnect and connect after 1 hour this will solve your problem .
If your problem still exists then in computer see whether any program is blocking the drive .
SAM ANDERSON
    Master:
  • 479 Answers
Remove all the connections and then refit all the connections tightly and firmly in proper place.
  • HP Master
  • 1,879 Answers
While it is connected, go to the Device Manager and check if the driver is loaded properly. If found, right-click and uninstall it then reboot the computer.
  • 10,594 Answers
Unplug and replug external dvd player in computer. Hope it works.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 07, 2008
    Seems problem of driver of external dvd drive.
    Please reinstall external dvd drive software and check again or
    go to control panel > add hardware and let Windows search it.
    Please update me to provide you more help.
    Unplug external dvd drive and then you should go to control panel > add hardware and get help of Windows to detect internal DVD ROM. This should be done as first priority. Because internal dvd drive will install software / drivers for external dvd drive.
    Shahid Electronics Oct 08, 2008
    Alright, one more attempt. Can you test external DVD Drive in another computer just to make sure that drive itself is ok?
HP Pavilion DVD player won't eject but plays the dvd
Try goint to My Computer and right click on the DVD player. If the eject works, the external eject switch is not working. If not, the mechanism is misaligned or damaged.
Oct 15, 2014 | HP Pavilion Computers & Internet
Vostro 1500 compaq cdr dvd player not work
Replace the CD/DVD player -- less than $20 for a new one.
Take the old/broken one to the computer-store, to get a new one with matching power/data connectors.
Feb 12, 2014 | Dell Vostro Computers & Internet
Hi. I connected my western digital HD to a DVD Player. It worked fine in the DVD player and still does but it does not work in a computer anymore. When you connect it up to a computer it seems to struggle...
I would assume the dvd player encrypted the drive so you could not copy the movies from your dvd player to your computer, so you could not burn them to prevent piracy. If you wanted to use the hard drive in your computer you will need to format the drive.
Jun 19, 2010 | Western Digital 320GB MyBook External USB...
The DVD player slide draw will not open or close
Check for a manual eject slide on the bottom near the front of the tray
Nov 21, 2009 | Philips DivX DVD Player
My NWD-B103 dosn´t turn it on, even if this is connected to the pc, it dosn´t reconize the divice.
First reset yours by the Back button;
If not solved;
Reset again by the button, the On the Computer by Fat32 Format, and then Copy the Initial Files that were on your MD when you Bought;
Good luck
Oct 28, 2009 | Sony Audio Players & Recorders
Hitachi DVD-ROM GD-S200
Did it come with a disk.? You may have to download the driver from manufacturers website. Good luck. Please rate me
Jun 18, 2009 | Hitachi (GD-S200) (GDS200) DVD Drive
No sound output and will not reconize Dvd's, but will reconize cd's
I'll take that as a no,
In fact the default for most types of media is media player but it doesn't include all of the relevant codex's you require for every type of media by default.
Most manufacturers include this software with their computers/DVDROM's but not always.
The reason I assume it is your codex not being installed is simple, you can play CD's, that means the drive works, media player works, sound card works and speakers work. The only common problem that would cause this is a missing or corrupted codex.
try something for me and let me know if it solves the problem.
Install VLC player http://www.videolan.org/vlc/download-windows.html
Then try to play the DVD using VLC player. If it asks to update itself, let it.
Comment back here once you have tried and let me know how you make out.
Chris
May 20, 2009 | NEC (ND-3540A Black) Burner
Playing movies from external hard drive
Hi rox09
Well you can rip your DVD to any external drive using and third party DVD ripping software ,once you do that you will get a AVI,MPEG and any common fomats your DVD player supports
Inorder to play those files in your DVD player ,you need the check whether your DVD has a USB input port or else if you laptop or computer has a S-video out put and your TV has S-Video input ;you can play directly from your laptop/computer to the TV using a S-video Cable which is available in any Computer shop.
I hope this helps
VJ
Mar 15, 2009 | ASUS Eee PC 900 Notebook
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
Mar 09, 2009 | Western Digital My Book Essential Edition...
LG V782W Combo DVD/Video Player - DVD won't eject
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Jan 30, 2008 | Televison & Video
Televison & Video Logo
128 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
