Question about Olympus VP-1 Projector Lamp
The machine is projecting a very purpe/pink image.
  • JamesNicknam Oct 01, 2008
    The probelem was solved by replacing the cable.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Check the WB, or else reset the camera back to factory default using the menu
Posted on Oct 01, 2008
Lamp is projecting pink
are you saying that all the images now have a pink colour to them. does the menu come up pink as well
Jul 07, 2011 | InFocus ScreenPlay 4805 Multimedia...
My tv turns on and i can see all images but everything is pink
Ur tv is missing a color.Reset ur tv by unplug,replug it an hour later.Check ur incommimg coalax cable.Check ur cable boxes or satalites boxes buy unplug it,replug an hour let the boxes reset itself,and upgrade it software.
May 02, 2010 | Mitsubishi WD-57732 Projection Television
IXD 420U projector takes a long time to project and has pink ima
If possible, try to replace the VGA cable between the projector and the computer. A bent or broken pin, or a damaged wire, can prevent the blue or green (or both) portions of the picture from being displayed. The result is a reddish/pinkish picture.
As for the long time to project an image, this could be an extended warm-up time. How old is the bulb in the projector? Does the projector have an option to display the hours used and/or remaining on the bulb? Bulbs do have a finite life, and when they near the end of their service life, they can become more difficult to start.
Hope this helps!
Feb 22, 2010 | Office Equipment & Supplies
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Has pink/green horizontal line across top l corner
Hi,if your tv is dlp or lcd you will need to replace the light engine that's in charge of creating the image and colors, and when bad you 'll get discoloration or lines across image.
Oct 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Pink image on Sony KP-53HS30 TV
Pink? If this is a retangular box that appears then I would suggest to look into the fact that you have turned on "TEXT" mode within the "CC" closed caption settings.
Jul 23, 2009 | Sony KP-53HS30 53" Rear Projection...
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
147 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
