Question about Kenmore Oasis HE 27082 Top Load Washer
Recurring "F" error code
I also have a Kenmore Oasis HE washing machine. Its just over one year old. My cycle starts fine, fills for about two minutes, then flashes an "F" at me. I have unplugged it, stopped and restarted, moved the clothes around, and spent hours on the phone with Sears to learn nothing.
Can anyone suggest a fix without paying for another service call.
Also, if anyone is interested in a class action suit, I'm all in! This was not a good purchase.
  • Anonymous Oct 09, 2008
    Sears repair is the worse I have ever seen. I have had my washer for 2 years and Have paid for the service agreement. It has been over 2 weeks since it stopped working. I made an appointment for 1 week ago the soonest appointment available. They never showed up I sat home all day waiting. They rescheduled for Monday after waiting for over an hour on the phone. They came out on monday and the person had np clue how to work with the computer. He called and someone talked him through on the phone. He was not even able to follow the simple instructions. He left thinking it was fixed. I put a load in and the F1 code started flashing with in 5 minutes. I called sears to reschedule an appointment. They would not even reschedule an appointment until the next day. They have no supervisors they say and I had to call back the next day. I finally got another appointment for Thursday. No one showed up today again and when I called they say I had no appointment scheduled. The next available appointment is Monday. That is 2 full weeks without a washer. I would say if you are thinking about buying from Sears...... Don't do it!!!!!!!
    Genius:
  • 1,028 Answers
On each corner about 2-3 inches from outside just under top are 2 clips push in with putty knife and lift top ..on cabinet side is a plastic bag with tech sheets pull them out and match f code(f followed by a number) this should give you an idea where to start
Posted on Oct 01, 2008
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
It has an F1 error code and stops. I have to wait a few minutes and then start it again. It will run for about 23 minutes and the code comes up again.
Check to see if the screens for your hot and cold water connections are plugged with grit.Or else the problem might be due to factory defect in the control circuit board of this washer. You have to replace the board.
Thank you !!
Jul 01, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Oasis HE Top Load
there are 4 rods holding the drum up, check to make sure all 4 are attached.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
77 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
