The machine stops at the first spin cycle unless you hit it. After that it finishes the cycle and cleans and drains perfectly
    Genius:
  • 1,028 Answers
Replaced lid switch if located on right side of lid opening if under left rear hinge try tightening scres in hinge first or pushing left hinge toward rear to better engage switch
Posted on Oct 01, 2008
I accidentally set cycle to Self Clean instead of Spin & Drain and pushed Start button. Trying to reset to correct cycle. Have just moved and don't have manual on hand.
Most machines will reset if you press the stop button or otherwise end the cycle. If all else fails, un-plug the machine, wait a few minutes and plug it in. Otherwise, just let the Self Clean cycle finish.
Nov 14, 2014 | Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Water would not drain and was slow to spin
Hi Rick.Now on the FISHER@PAYKEL machines they will not spin properly unless all the water is out of your machine.Please look underneath the machine for me and you should see the pump which has a fan attached to it .It is located to the front right.Now turn the fan clockwise and anticlockwise a few times to loosen the pump as it may be jammed.The fan should freely.To look under the machine 1st you must bail some of the water out by hand with a small bucket or pot,enough to lean the machine back so you can look under the machine without it leaking everywhere.Now once the fan turns freely put it back on its feet and select a spin cycle and push the start button.Hopefully the machine will start to drain and spin.Please reply back on how you got on or if the machine still does not drain.
Aug 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Spin cycle slow unless hose lowered
you will have to take the hoses off the pump and clean the pump out its probably got sand in it
Apr 23, 2009 | Washing Machines
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
Sep 21, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
