Question about Dell Inspiron 1501 Notebook
Black screen with mouse pointer and taskbar
When i go into my computer to see my c and removeble drive its not there. then the screen goes black when i exit
  • 30 Answers
Had the same problem with a friend of mine. Turned out to be MalWare interfering with security accessibility. Had to re-install windows. But id you have a restore point I would try that.
don
Posted on Sep 30, 2008
To adjust rotating display of laptop ,taskbar with all icons moves on different(bottom to top)
Step 1:
Has your Windows taskbar suddenly moved to the side of your desktop screen or even to the top? This can be very disruptive to your daily computing, which may mean a loss of productivity at work. Your taskbar could have moved because of a glitch in programming or an inadvertent mouse click while you were focused on something else. The latter is more common and is usually the result of an unlocked taskbar.
Older Windows Operating Systems Windows 98, Windows ME, Windows XP and Windows Vista all utilize similar solutions for this problem. For the quickest route to returning the taskbar to the bottom of the screen, first place your mouse pointer over empty space on your taskbar (space not occupied by an icon or a button indicating an open program) and right-click. Look near the bottom of the menu that appears for the "Lock the Taskbar" listing, and make sure there is no check mark next to the listing. If there is a check mark, it means the taskbar is locked and cannot be moved, so click on the listing to deselect (and unlock) it. With your mouse pointer again over an empty space on the taskbar, click and hold the left mouse button and then move the mouse pointer to the bottom of the screen. When you release the left mouse button, your taskbar should have moved. As long as the taskbar is unlocked, you can also vary its height. Hold the mouse pointer over the upper edge of the taskbar until it becomes a double arrow (pointing up and down). Then click and hold while you drag the upper edge of the taskbar to the you desire. Once you have the taskbar where you want it, remember to lock it again by selecting the listing on the right-click taskbar menu.
Another option is to visit the Microsoft Windows website and download and run an automatic "Fix it" program, which should take care of programming issues. Windows 7
There are three options for moving the taskbar in the Windows 7 operating system. The first option involves right-clicking on an empty space in the taskbar and then navigating to the "Properties" menu (look near the center of the menu) to set the location of your taskbar on your screen. This menu also allows you to change or establish a number of other default settings relating to your Start menu and taskbar. The second option is exactly the same as the first process given for the Windows operating systems previously mentioned. And again, to prevent the format you have established from changing, lock the taskbar by right-clicking on an empty space of the taskbar and selecting "Lock the Taskbar" from the menu. The third option is a bit more involved and requires downloading registry files (files ending in ".reg"), saving them to your desktop and then double-clicking on them to merge them with your operating system. The files can be deleted after use.
Microsoft online support
http://support.microsoft.com/kb/253679
Feb 17, 2013 | Dell Inspiron Mini 10 Notebook
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
Black screen during log in
Try booting in safe mode by hitting F8 every second after you turn it on until the boot screen comes up. Then select "safe mode" If it loads up in safe mode then delete the graphics driver from Device Manager.
If you were able to delete the driver in Device manager then reboot and get the driver from here:
http://www.dell.com/support/drivers/us/en/04
May 15, 2012 | Dell Obsidian Black 15.6" Inspiron N5050...
Help! My Dell Inspiron Desktop (Windows 7) went into sleep mode, I shook the mouse to use it and got a black screen with just the mouse pointer. I powered down & back up, got the Dell screen and the...
My guide might help you, it's worth a try, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Sounds like a windows error though, some how the installation may have been corrupted. I suggest performing a virus scan on a test PC. An alternative is to take it in to a computer technician.
Thanking you
Happy testing
damnor01
Nov 15, 2010 | Computers & Internet
My computer loads up the icons come on but the status bar at the bottom is missing can not set or start the "start" event. iam getting an infiltration message and antivirus message from antivirdog.com but...
The Taskbar at the bottom of the screen is set to Autohide. Move your mouse pointer to the bottom of the screen and let it stay there for a few seconds. The Taskbar should appear.
Sep 12, 2010 | Acer Aspire X3200 PC Desktop
The taskbar disppears. I have it locked so that it should always be on top of everything else but when it goes into hibernation and it restarted it disappears.
I'm had the same problem with my system. if the 'Start' button is still visible, so you can right-click that, select 'Properties' and change the TaskBar settings.select the 'Autohide the Taskbar' and applying that change will result in the Taskbar appearing again (at least when the mouse pointer is positioned by the Taskbar).
if the above one does not work a simple solution that will work:
1. Hit CTRL+ESC to show the Start menu.
2. Right click the menu at the bottom for Properties.
3. Select the Taskbar tab.
4. Check Autohide Taskbar and click the apply button.
5. Uncheck Autohide Taskbar and click the apply button once more.
Your taskbar should reappear when you've completed these 5 steps.
Please give this a try before messing with registry or recovering your machine!
If the taskbar does not show up when you press CTRL+ESC then explorer.exe may not be running. To correct this press CTRL+SHIFT+ESC which will bring up the task manager. Click File, New. Find explorer.exe and open it.
Go into Task Manager. Find explorer.exe and end the process. Restart explorer.exe. If your taskbar magically reappears, you've found the issue. Here are some other symptoms:
After a Windows Vista-based computer has been running for an extended period of time, the desktop screen may stop updating correctly. For example, you may experience any of the following symptoms: • Parts of the screen may go black. • Parts of the screen may become transparent. • The toolbar may disappear. • The toolbar may appear at the top of the screen instead of at the bottom of the screen.
If you add the GDI Objects column for the Explorer.exe process in the Task Manager console, you see that the GDI Objects column has reached the maximal number that is defined in the GDIProcessHandleQuota registry entry.
A hotfix is available from Microsoft: http://support.microsoft.com/kb/932406
Jan 07, 2010 | ASUS Eee Box EBXB202-WHT-E0002 Intel Atom...
Screen problem
From your description of the problem, it looks as if the screen has rotated by 90 degrees.
To solve this problem, just press CTRL+ALT+UP arrow keys together. Hope this solves your problem Thanks.
Jul 21, 2009 | Compaq Presario 700 470024-192 Notebook
Black display after vista splash scrren
You may have an infection.
Anyways...this is what you should do to regain control.
When you get to the black screen and the mouse pointer, press Ctrl+Alt+Del
The next screen will ask you what do you want to do...
Select Task Management....(one of the last if not the last option)
You'll get the Task Manager Windows.
Go to the Processes tab
On the File menu choose New Task (Run), and type: explorer.exe
Wait a little bit, and your desktop should come up.
Once there, run an antivirus antyspyware, anti adware etc, to get rid of the problem.
Once you KNOW you're clean and back in track, I recommend you to look into www.labellpcsolutions.com.
They have a product called Pc Guard, that protect your computer from all this problems effectively.
Please don't forget to rate this answer if helps.
Jul 02, 2009 | Compaq Presario 700 470024-192 Notebook
Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Apr 20, 2009 | Dell Inspiron 1525 Notebook
Black screen mouse pointer visible after i enter my password
hi..this problem is due to the loading drivers
during the time of login.The reason for the problem
may be due to the following reason.some files could
have got corrupted while loading drivers that may be
some damage due to the windows file corruption or
due to the virus corruption.
try it out..
thank u..
Feb 05, 2009 | HP Pavilion dv4000 Notebook
Dell Inspiron 1501 Notebook Logo
48 people viewed this question
Alun Cox
