Question about Canon imageRUNNER C6800 Copier
Canon IRC6800 error code 0A0A ( residual jam i.e. paper jam)
How to troubleshoot the residual jam in canon IRC6800 when there is no paper which is jamed. Could be sensor issue. Please comment.
  • surenderg44 May 11, 2010
    error code E000006-0001 PLZ Solve this problem
  • khamral BAKSH May 11, 2010
    that is the sub code what is the error code
    New Friend:
Canon IR105 error code 0A0A
Posted on Feb 13, 2013
MXM450
  • 62 Answers
SOURCE: PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Posted on Jan 22, 2009
SOURCE: Canon PC980 ADF PROBLEM
not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
Posted on Feb 13, 2009
tareq857
  • 7 Answers
SOURCE: i am receiving an error of canon ir 1210- rec.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Posted on Mar 16, 2009
copiersplusw
  • 136 Answers
SOURCE: Canon PC-745 stopped working.. paper jam light
I seen this problem before, You need to call a Service technician And tell him you may have a Paper Feed Problwm so tires may be needed
Posted on Sep 13, 2009
xptareq2000
  • 1447 Answers
SOURCE: Canon imagerunner 2230
please chack paper feed senonso in paper feed section or delivery section where is fuser unite some times sensor is open or displace
Posted on Nov 04, 2009
Canon irc6800 error code E000061-0005
Have you checked corona assembly wheter the wire is not damaged/missplaced? From my memory this error means either that or problem with voltage on drum in general. (corona and/or laser shutter issue)
Apr 12, 2016 | Canon Office Equipment & Supplies
How to fix canon irC6800 error code e00008-01
Fixing roller must be changed,After replacement U have to reset machine in service mode COPIER COUNTER DRBL1 FX-UP-RL.Than turn machine on and off
Nov 09, 2014 | Canon Toner, irc6800, 5058/68, ma
Fixing roller has exceeded a specific count.After you repled it reset in service mode:COPIER<COUNTER<DRBL1<FX-UP-RL,and turn machine OFF and ON
Problem with fixing assy. Fixing roller needs to be replaced. After replacement U have to execute,reset it in service mode COPIER COUNTER DRBL 1 FX -UP-RL .
Canon error jam
for this case you must call technician for chek it.
because the technician have to detail to chek it.
- position of paper.
- condition of paper.
Feb 27, 2013 | Canon CLC 1180 Copier
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
May 16, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon imageRUNNER C6800 Copier Logo
850 people viewed this question
old marine
old marine
