Kenwood excelon kdc-x495 how do I unlock it? is there a reset button or?
SOURCE: how to i reset the password
this works or kdc series gear... try it and see
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
else try this
use the remote and press 55222277 nothing will happen until u put in the last numbers.
SOURCE: i pressed my radios reset
Per page 26 in the following manual: http://www.sirius.com/pdf/manuals/kdcx679.pdf
The security code can't be changed, once it's set. Did you go through the sequence of steps on page 26 of the manual?
If you did (in fact) lock in and approve a security code, you'll need to contact Kenwood support and prove ownership (e.g. receipt) before they can give you instructions for resetting the code.
There is a hack for the ASIC that stores the security code out on the Internet (use Google to find it).
If my response helped you, please reward me with positive feedback (Fixed it!). Thanx!
Lounatech
SOURCE: i have a kenwood excelon
If the screen did not even light up, then you definately have a power issue. Verify that your fuse did not blow, and then that you connected the correct wires. The power wires are usually orange and red. Red being the "always on" and orange being the "switched source".
