Question about Gateway FPD1975W 19" LCD Monitor
Monitor flashes my monitor will not turn on it just flashes?? Can you tell me whats wrong
    Novelist:
  • 159 Answers
If the power button flashes, You probably have a bad power-inverter board thats needs to be refurbished due to burned out capacitors and possibly a transistor or two.
If the screen flashes and the power button stays steady, it could be the same thing or a bad bulb in the screen.
Fran
Posted on Oct 11, 2008
HP L1908W When i turn on the monitor, it turns on for 1 second and goes off.. Can u tell me whats wrong?!? i think maybe the inverter... Thanks, faisca
First use an external light sorce like a LED flash light. With it close to the screen do you see a light ghosty image of the desktop?
If you do then either your backlight's or backlight power circuit have failed. If the monitor is not under waranty some repair shops may be able to fix the problem.
If there is no image then the LCD is not conecting to the main board and the monitor will need to be replaced.
If you want futher details on the first instance contact me
Sep 12, 2011 | HP L1908W 19" LCD Monitor
My Everex eXplora GS28 has no video on monitor
In your case, you may need to take step by step in order to find a culprit in what is causing the error. In a situation where you have no display on your monitor, there are many possiblity to the issue, and the best case scenerio to solving this promblem is having extra testing parts in order to actually know what is wrong. However 1) Check your monitor, if it's on, cable if they are secure and proper (power hdd lights) and if there are, take note of it and come back to tell us and we might be able to tell you what is wrong. 3) You will have to take this to a computer technician, as video card, bios, chipset, memory, cpu, or simply the motherboard is bad.... and the only way to make sure what is wrong is to have extra part to test this with. if it is giving you beeps, lights flashing, shutting down, and restarting automatic can better tell them/or us what is excatly causing the error. Sorry that this is no solution.... but before you do that, take your computer side panel off. when you see the motherboard ( the board with a fan and cable wiring going into) there is a battery about the size of a nickel and silver like a nickel, try to take that battery out, leave it out for a few second like 15sec, and then reinsert it back in, and then out everything back togheter and turn on your computer to see if anything work, if not, you have to take this to a tech to see what is actually wrong.
Feb 06, 2011 | Everex DESKTOP PC EVEREX | GPC TC2502 RTL
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Temperature monitor of freezer flashes
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Freezers
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Monitor goes blank less than a second after turning on.
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
LCD Monitor has no video
Sounds your monitor has either blown a backlight or the inverter board is bad. Either way they can both be replaced, but tracking down the parts will be a bit difficult. But your LCD Monitor is in trouble! Sorry!
Oct 03, 2007 | ViewSonic VX910 19" LCD Monitor
Tecra M2 screen failure
Bad RAM probably bad system board. You say there are flashes usually you can check any available beep or flash codes. Sometimes they will tell you what has malfunctioned. Check the mfg. website or manual for diagnostic codes. As for the external monitor you will have to press function F4 or F8 or whatever function key you have with a monitor picture to switch to the external display. Hack
Jul 07, 2007 | Toshiba Tecra M2 Notebook
Gateway FPD1975W 19" LCD Monitor Logo
946 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
