Question about Acer Computers & Internet
Cannot get acer aspire laptop to be displayed on television using s video to s video cable. How do i do it?
    Problem Solver:
  • 13 Answers
What is your version of your acer,, older acers,, like my moms,, can't do it either cuz the videocard isn't programmed to display it on your television,, tell me your whole version like :Acer Aspire 8920,, then i can help you further
Posted on Sep 30, 2008
Acer Aspire 5630 hook up to television
Your Acer laptop has a 15-pin VGA port on the rear. It may also have a S-Video and/or a DVI-D port. Any of these can be used to connect to a television monitor. None of these connections, however, supports the sound portion of the signal. You will therefore require two cables, one for the video, and one for the sound. The sound will be a regular 1/8" stereo jack on the PC side. You will need to look at the TV to see what types of connections it accepts. There may be HDMI, DVI-D, S-Video, or RCA connections. Select a cable which matches the connections for each end for both the audio and video.
Dec 11, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
I HAVE TRIED VARIOUS CABLE TO CONNECT MY ACER
Pls try a S-Video to S-Video cable. Power on TV, then PC.
pls send us your feedback if the above helps. Thanks!
Mar 05, 2010 | Acer Aspire 5520-5908 Notebook
Hi i have an acer aspire one....i want to play movie through TV
I would recommend you s-video. I also have an Acer Aspire and s-video is working perfectly. you have to change the second monitor's resolution on your PC to the display and frequency of the TV. The most common configuration is 800x600 display with a 60mhtz refresh rate (frequency), and send the image through the additional monitor (your TV).
Aug 26, 2009 | Acer Aspire One AOA150-1983 Notebook PC
How to connect my Acer Aspire 5670 outgoing to my TV? I have an SV cable and I believe there is an sv output plug for it. I'm not very technical.
You laptop can connect to any television or display device with S-video input through the S-video/TV-out (NTSC/PAL) port, located on the right side of the laptop (this is the round whitish port located between the two USB ports and the ventilation slots.
The computer has also an external display (VGA) port by which the laptop can be connected to a display device (e.g., external monitor, LCD projector).This is the port on the right side nearest the end of the computer.
Jul 27, 2009 | Acer Aspire 5670 Notebook
Not able to connect my Acer Aspire 4720Z notebook to TV
You will need to change the TV's input select to S-Video to view your notebooks display. Remember S-Video is just that, Video and no sound. You'll need to patch the audio in via Audio In input on the TV if you haven't already?
Jul 22, 2009 | Acer Aspire 4720 Notebook
LCD cable?
It is called video cable, and it is a ribbon cable, sometimes called LCD video cable.
The cable depends on the model and on the size of the display.
Here is a reseller: Notebookparts.com: VIDEO CABLE
Apr 03, 2009 | Acer Aspire 4520-5582 Notebook
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Acer aspire 4315 connect to TV problem
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
Sep 10, 2008 | Acer Aspire 5050-3242 Notebook
Connecting my acer aspire 5100/5102 to my tv via cable
There are a number of possible ways to getbthe display up onto your television. Im not certain which colours to use with which but once its all plugged in you will need to hold down the FN (funtion) key and press one of the F1-F12 buttons. to work out which one you just need to look for a button that looks like a screen or two screens and that should make the display external. good luck
Feb 07, 2008 | Acer Aspire 5102WLMi Notebook
Configuration to display video on TV using Acer Aspire 5052 laptop
just right click on an empty space on your desktop and you will get the options to clone or extend desktop.
Oct 09, 2007 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
