Question about Kenmore Elite HE4 Electric Dryer
The clothes dried on high or medium heat come out smelling like heated metal
I used to dry my towels on medium high setting but they would come out smelling like over heated metal (no fresh dryer sheet smell) so I started drying the towels on the medium settting and the same thing is still happening. Don't really notice the smell in the clothes, only the towels. Any thoughts on what may be causing this? Thanks!
  • Anonymous Mar 17, 2014
    It drys lite clothes but jeans or towels
  • 943 Answers
Hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Posted on Oct 02, 2008
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
What is the best setting to use to dry clothes
Medium or low heat and put a few DRY,clean towels in there.
AUTO moisture sensors will do the rest.
The HIGH setting is not good for the dryer or your clothing.
Always put in a dry article to speed the process up.
Permanent press w/cool down is good.
If you use the HIGH setting,you better be **kid and waiting for the clothes to be dry!
Sorry.
Aug 26, 2013 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
How do I use my Griddle for the first time? We did not get a manual I would like one sent to us.
I can't help you with the manual because you did not provide the make and model number.
Typically, you wash the griddle with soap and water (DO NOT WASH ANY ELECTRICAL CONTROL UNIT!). Rinse and let dry if it has a non-stick coating. If it does not have a non-stick coating (bare metal), towel-dry the griddle, then put some vegetable oil on a paper towel and wipe the entire cooking surface so it is covered with a thin film of oil. Heat it to about 250 °F for about one on-off cycle on the electrical control. It is now "seasoned" and ready for use. If the griddle does not have an electric heater but is designed for use on a range-top burner, set the burner to just below medium heat and heat until water droplets splattered on the griddle boil off quickly.
May 30, 2011 | Microwave Ovens
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Delic ate cycle taking too long to dry
This is normal because the delicate cycle is a low heat cycle.
Aug 01, 2009 | Dryers
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
There is no difference in drying between medium and high setting.
You only need a certain amount of heat and air to evaporate a given amount of water. If you don't notice any difference, use the medium setting. You would notice a difference with a larger load.
Feb 20, 2009 | KitchenAid Dryers
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
346 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
