Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Memory card i have purchased an 8gb memory card for my samsung tocca but when i put it in the phone the following message appears -memory card has unrecognised format, reformatting will erase all data. Reformat now? (not a problem as i have all info backed up on pc) but when i try to reformat it it just comes up error and wont let me save anything to the card
  • Anonymous Jan 14, 2009
    Mine's doing this aswell
    Champion:
  • 203 Answers
Take out the memory card and put it in a card reader And reformat the card from comand promt that should fix it. TYPE ON RUN CMD an black screen type:  FORMAT /F  C:  THE C: IS THE LETER OF YOUR HARD DISK BUT INSTEAD OF C: PUT THE LETER OF YOUR CARD COULD BE E: F: AND SO ON.IF THAT DOES NOT FIX IT TRY ON THE COPMUTER MANAGEMENT, I HAD THE SAME PROBLEM AND IS OK NOW .
Posted on Jan 16, 2009
I have bought 8gb memory card and put some songs then i install it in samsung curby2 but it shows that memory card is in unrecognised format.the phone cant support it?
You need to format the card. If you have an otion under memory in settings, sometimes there is an option to format the card there. Otherwise, put it in your computer, go to the samsung site or a format card site and format it for your phone. I transferred all my contacts to a card and there was no order to them, I had forgotten format the SD card. This doesnt happen on a SIM card...only CDMA phones with SD cards
Mar 31, 2013 | Cell Phones
I can't format my new micro sd card
The Samsung Alias works with microSD cards. Your 8GB card is actually a microSDHC card and will not work in devices not designed to work with them. You need to use a microSD card, 2GB or smaller.
Jan 19, 2013 | Samsung SCH-u740 Cellular Phone
My Samsung GT-S3650 shows ''memory card has an
Try removing the memory card and plug it into a PC to format it.
  • For desktops you'll usually need to buy a card reader, but most laptops have these built in. Keep in mind that you may still need an adapter to plug it into the card reader itself (usually, micro and mini SD cards need an adapter which converts them into a full-sized SD card).
  • Once you have plugged the card in to your computer, open "My Computer" and right click the drive.
  • Select "Format" and leave the options default, click OK.
  • Your card should be ready to use in your phone.
Jul 03, 2011 | Samsung Lands Phones
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
How to expand samsung s3500i's memory to 8gb
samsung s3500i support upto 8 gb memory card you can purchase 8 gb micro sd from market , remove the battery of handset u see there is port , put the memory card into the slot
Apr 11, 2010 | Samsung Cell Phones
How do i format a 8gb sandisk microsdhc card to my new samsung sgh-f480i mobile phone
Use an adapter to put it in your PC, then use the windows format tool to format it as FAT32.
Nov 13, 2009 | SanDisk 8GB microSDHC Memory Card with...
Samsung gravity PNY 4gb memory card problem
The samsung gravity does not support HC cards. I had the same problem and purchased a regular MicroSD card and it works fine. hope this helps.
May 27, 2009 | Samsung Gravity SGH-T459 Cell Phone
Lost all memory on my memory card (phone)
Try using recovery applications. There are lots out there. Just Google them or try Download.com.
A good one tho is PCInspector which is also free. (pcinspector.de).
Good luck.
My problem is a bit different. I have an 8GB SanDisk MicroSD which I've used on my Samsung Tocco phone for about 4 months now. Everything was fine and I had lots of pictures and videos on it. I used to use my phone cable to transfer the data onto my PC but then for the first time I put the card into the card reader (USB adapter) which came with the card when I bought it (in the same package). I could see the photos and all the folders for about 10 seconds on my PC but then suddenly it stopped working and when I connect the card reader to the PC it just shows a Removable Disk which does not show any info (no size nor anything else). And when I click on the disk it says "Please insert a disk into drive X:.". And when I put the card into my phone again, it says unrecognised format and asks me if I want to format it. I've tried it on a different Tocco phone as well but the same message. I've used 4-5 different recovery programs and the only one that only shows that drive in the program is PCInspector but does not let me do any actions on it. So basically all the other programs don't even detect the drive and PCInspector doesn't let me do anything with it! Guys I'm lost! Can you help please??? I have lots of pictures and videos which are extremely valueable to me and I really want them back. Any suggestions welcome and I would appreciate them! I'm really desperate, pleaseeeee!!!
I'm looking forward to any suggestion.............
All the best.
Fred
Jan 16, 2009 | SanDisk 2GB microSD Memory Card
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
172 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
