Question about Lexmark X5470 All-In-One InkJet Printer
Grinding noise when printing and cuts paper
When printing the copier makes a grinding noise and makes a perforated line down the length of the printed copy.
  • Lexmark Master
  • 4,338 Answers
There may be something stuck in the area of the perforation, like a paper clip, paper debris or some foreign material. I would look in that area with a flashlight and see if there is something in the Paper feed roller area.Something may have come loose if you had a paper jam. Let me know.
Please remember to rate all users who assist you for free :)
Posted on Oct 04, 2008
If you have replaced a toner cartridge recently, eject the cartridge again and reseat it correctly.
Apr 25, 2014 | Dell Office Equipment & Supplies
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Canon mf6530 crumples paper and makes grinding noise when trying to print.
I pressume that paper is wrinkled in fixing section. Probably the fixing bushings are worn out. The grinding noise could be from paper when it stuckes, but also from gears.Call service.
There is a trick if paper is moisturized. Flip paper in cass. up side down, and try again.
Jun 14, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Printer makes grinding noise and not printing
sounds like the rubber band in side the printer has jumped a tooth which is why it is grinding bud have it repaired or get another
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Perforations on paper
I can't find anywhere on Canon's information that it has the ability to perforate as a setting.
This sounds like that is something dragging from the print head that is causing it.
I would take it back to the shop you got it from, and have them replace it.
Make sure to take an example of what it is doing when it prints.
Jul 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Cradle made grinding noise and now machine wno't turn on
My Alps printer makes a grinding noise and won't pull the paper through much less print. What do I do - I print diplomas with this printer.
Apr 30, 2008 | Office Equipment & Supplies
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark X5470 All-In-One InkJet Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
