Question about Philips PSS110/17 MP3 Player
Philips pss110/05 problem connect to computer
I only have a vista operating system and cannot get hold of a xp, i mistakenly formatted it and i cannot fix it pls. help me
  • 8,596 Answers
This model is completely incompatible with Vista, and your problem ultimately will probably not be solvable.
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
    New Friend:
My pss110/00 said : problem please connect to computer
Posted on Mar 19, 2016
I cannot format vista to install xp
If your vista is active it will not let you format the drive to install windows XP you have to shut down the computer , put the XP CD in the cd drive and start FROM THE CD, at this point you will follow the Xp installation Instruction and come to a page where you will have the possibility to format the partition where vista is installed,
Note, you should look for ALL rhe XP driver of you computer model BEFORE you do this sometimes a computer sold wit Windows Vista do not have any XP driver for all the peripheral installed in that computer
Jul 22, 2011 | Computers & Internet
I have a 40GB HDD with dual operating system Win XP & Vista. Now Win XP not work properly. So I have to format that HDD n install only one operting system Win XP. But Win XP bootable not work properly...
Hi and welcome ygshaikh !
Here is one solution ( there are maybe others ) easy to use if your pc is a desktop :
extract the hdd from your machine and connect it to a healthy computer ( in a external USB box or strait inside the pc ) . Format the drive and reinstall it in your machine . You will now be able to install Win XP .
Best regards .
Feb 14, 2011 | Computers & Internet
Windows could not start because the following file is missing or corrupt: windowssystem32configsystem
only one solution: reinstall windows using the Dell Recovery CDs that came with the computer.
Jan 18, 2010 | Dell Inspiron 2200 Notebook
Error Loading Operating System
the two operating systems are not compatible. I assume that you are trying to rollback to XP on the computer. The problem is to remove the Vista o/s and install XP.
Oct 05, 2009 | Computers & Internet
I want to install xp by removing my pre installed vista in presario cq61-132tu. and there is no option of sata in bios so plzzzzzzzzzzz help me. i want to operate only xp means i m not want to install both...
Put XP disk in CD-ROM and reboot the computer.
Click yes to install XP. It will tell you there is a system already installed on C drive. You select to install XP on C drive. It will ask if you want to format C drive, you select full format.
XP will then install
Sep 24, 2009 | Compaq Computers & Internet
NEed to get rid of Vista
if your operating system installed in your computer is vista then you want to change into win xp,,, just insert you os xp into cd roon drive then boot it..by preesing f12 in acer, dell,toshiba, and others..
then follow the instruction bellow..
format then install the os xp..
after that you uninstalld the vista then you install also the xp..
thanks
Jun 01, 2009 | Microsoft Computers & Internet
Not recognising in computers
You need to have Windows Media Player 11 instaled or else it won't recognise it.
Mar 25, 2009 | Sony NWZB133F MP3 Player
Formating problem
hi i have sony vaio VGN-NR-220E i want to know how i can format this system there vista operating i want Windows xp
Aug 22, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Pss110/5 system problem
The PSS110 is not fully compatible with Vista.
You can download the Philips Device Manager for the PSS110 from:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=SHOQBOX_SU&session=20080627080823_82.5.154.61&grp=PORTABLE_ENTERTAINMENT_GR&ctn=PSS110/05&mid=Link_Software&hlt=Link_Software
The software is not Vista compatible so you will have to run it on an XP machine.
Run the Device Manager and select the repair option. This will update the firmware and replace the system files.
Make sure the player is connected to the mains during this process.
Use the Philips Device Manager
Jun 16, 2008 | Philips PSS110/17 MP3 Player
Philips PSS110/17 MP3 Player Logo
1,118 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
