Question about Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television
Connecting TV to cable service for HDTV
Is a converter or adapter required for connecting this device to a cable provider (WOW) for the reception of HDTV. Can the required adapter be purchased or should it be leased from the cable provider?
  • machineman76 Sep 30, 2008
    That's one thing I'm trying to determine. The back of the projection TV has a set of seven RCA connectors grouped as "DTV", but the owner's manual in Appendex B lists a series of voltage levels for those inputs suggesting they analog inputs. There is also a "MonitorLink/DVI" connector on the back with a notation in the Op Manual that "The DVI-HDTV input terminal is compliant with the EIA-861 standard and is not intended for use with personal computers" The connector does not look like the HDMI connector.
    New Friend:
  • 161 Answers
Normally you need a converter box for hd because normal stations are broadcasted in hd.....its not common enough for them to do it...and you probably have to buy a package with your cable company for the hd channels. another your tv hd ready?
Posted on Sep 30, 2008
Will this tv work with an antenna or does it need a converter box?
All LCD tv's made in the last 10 years support digital tv out of the box and do not need a converter box. However if you want to pick up local stations over the air, you may need an external antenna. Otherwise if you have cable tv or other services, you can connect your service to your tv directly.
You may also want to call your service provider (if applicable) if you have issues connecting it to your tv.
Mar 25, 2011 | Sylvania 6615LE LCD HDTV
Will i need a converter box for this tv?
If you want to receive off-the-air broadcasts (i.e., you have no cable satellite system), then yes, you'll need a digital tuning adapter. This set has only an analog tuner.
If you are on a cable system, you might not need a converter box, but it depends on your cable provider. Some systems still offer basic cable service without a box, and you can see what channels you'll pick up with the TV set for "cable" tuning. Other systems require a digital converter box or "digital transport adapter" for any reception. You'll need to check with your cable provider to find out.
Feb 27, 2011 | RCA F36648 36" TV
My wireless USB adapter is not getting connected to the network, what do I do
prior computers have builtin network adapters that functioned as cable connection either dial up phone lin or ethernet cable connections. Computer of the recent generation have wireless adaptors that derive connective within radius of modems also known as wifi. Observe the computers made models as reference to ascertain whether requires cable connection to network or capable of wireless reception. Computers that are provided network structures by an expert would recognise either as requiring cable or wireless. Depending on the coniditon of computer structures requesting to establish a network structure is acheivable. Refer with a computer networkin technician that would evaluate the devices at the location to ascertain the requisite structures to establish networking telecommunications. For example, refering with an expert ascertains that the computer requires modems to capture the signals or modern devices require a miniature adaptor device attacked to the computer.
Feb 19, 2011 | Linksys Computers & Internet
Does the Phillips 60 HDTV rear projection require an analogue/digital converter?
Unless you are using a cable tv provider to receive your local channels you will definitely need a converter.
Depending on the cable provider will determine if you will need one at that time.
Feb 16, 2011 | Philips 60PP9202 60" Rear Projection...
How to hook antenna to tv?
optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. the exact type and positioning of the aerial will depend upon your particular area your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable,turn off all main power switches. vhf or uhf it must first go to the media box and you will see the input aerial cable connect it there and the output go to the back of your tv that indicates aerial input terminal.
Oct 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have power to my W.D. but it will not connect to my computers
Check the power cable The My Book and Elements desktop devices use a power adapter to operate the drive and hardware. Portable devices rely on the data cable for power and data.
  • Check the power cables are well seated in the external drive (applies only to Desktop external drives), and also the AC socket the power adapter is connected
  • Connect the device directly to the computer. For troubleshooting it's best to ensure the data cable is connected directly to the PC or laptop. Do not connect the device through a non-powered USB hub. Similarly make sure the power adapter is connected directly to a wall outlet, to rule out a degraded surge protector or power strip
  • If this is a My Passport or Elements Portable drive, ensure the data cable is connected securely to the drive, and the computer's USB port. For troubleshooting only, do not connect via a USB hub, to rule out power related concerns
  • My Passport and WD Elements Portable devices may benefit using a Power Booster Cable to use two USB ports, in order to provide extra power to the device
  • Use a USB hub with its own power adapter. These units provide 5V, and up to 1000mA to each USB port; and may be a good alternative, if a Power Booster Cable is not available
  • Test with another power adapter. Take note of the input requirements at the power port of the desktop device for voltage and amperage. Be sure the output of the power adapter does not provide voltage higher than the device's input requirements. Higher amperage will not harm a device, but higher voltage will destroy a device
Check the data cable Data cables can degrade over time from bending and flexing. The connectors can get bent, or the internal pins may corrode from moisture or other contaminates.
  • Use a different data port
  • Use a different data cable
  • Use a different computer, if possible
Dec 28, 2017 | Western Digital My Book Premium ES...
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Does the Sylvania 22 HDTV require a special cable when connecting to my cable service. I do not have HD cable service.
Not necessarily. You can use the normal connecting cable but you may not get HDTV picture. Better is to connect through HDMI cable where you can view HD pitures on the channels transmitting HD programmes
Jan 06, 2010 | Sylvania LC-225SL9 22 in. LCD TV
Don't know how to activate HD reception on M and S HD ready tv
Not an HDTV this is an standard thin flat tv,not possible to get HDTV,only get DTV with a converter box for free air,or cable,satalite or telicom signals than not require converter box.
Oct 22, 2009 | Emerson EWF2004 20" TV
We recently purchase 2 TB1 10MW9 DTV Digital Analog Converters to connect to 2 of our Ananlog TV's. Our TV reception is from Comcast Cable & we had then set-up our Main TV with their converter. Our...
U have paid cable, u don't need the converter box.Not even the analog tv require the coverter box, if u have paid cable or satalite tv or telicom signal.All ur tvs is hook up to the Comcast Cable correct?That all u need not, require the converter box.
Sep 03, 2009 | Televison & Video
Mitsubishi WS-48313 48" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
