Question about RCA R52WH73 Projection Television
R52WH74 I'm trying to connect my computer with my TV via HDMI. I can see the computer on the tv, but the whole thing doesn't fit on the screen. I have tried all resolutions with it as well. The type of graphics card that I have is a 3D Accelerator ATI Radeon X1950 XT (R580). I used to play my Xbox360 on this tv in 1080i mode, but for some reason it really won't let me use my computer in the same fasion. Thank you to whoever can fix my problem in advance. :) Confused
  • Kevin Creech Oct 01, 2008
    I would like to post a correction. I'm not using HDMI I'm trying to use DVI to do this. I'm using a HDMI cable with a DVI adapter that goes into the back of the R52WH74 from the computer. Sorry for any confusion.
    Jensenka
  • Anonymous Apr 11, 2009
    Same problem i'm using DVI to HDMI converent to DVI
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
Lowest screen setting for ANY other screen can be an awlful default size. So if two or more screens to watch the computer are connected then this can happen.
Posted on Jun 13, 2017
Slapnuts1975
  • 51 Answers
SOURCE: RCA r52wh74
IrishDruids advise, while be it appropriate for most brands, is not applicable on a RCA. The fuse location is on the main power supply, its not a glass fuse, but a box fuse at location fl231. You will also have to replace diode dl231.
Posted on Jun 04, 2008
SOURCE: RCA HDTV (HD52W59) and Playstation (PS3) Screen Size Issue...
First of all the adapters always give headaches with these TV's for some reason. Try changing to 16:9 instead of Cinerama. I do this by using the direction buttons on the remote left and right change this. Hope this info helps.
Posted on Jun 19, 2008
ladywinn
  • 5138 Answers
SOURCE: Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Posted on Feb 08, 2009
localwonder
  • 6784 Answers
SOURCE: 3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Posted on Feb 13, 2009
moorah1
  • 181 Answers
SOURCE: When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Posted on Feb 16, 2012
HDMI PROBLEMS
sounds like the picture on you tv is set on fit to screen mode try under menu set picture to different setting there should be a normal setting
Mar 02, 2014 | Toshiba 42AV500U 42 in. LCD HDTV
My Sansui HD LED TV cuts the border of my frames when I connect my PC
To fix this go into your screen resolution settings on your computer while connected to your TV. Start at the highest possible resolution and keep moving down 1 setting at a time until you get to a setting that fits the screen perfectly.
Oct 20, 2012 | Sansui Televison & Video
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
I am trying to connect my new apple tv to my panasonic bt205 ht and then to my samsung tv. As I have only i HDMI socket in my Ht I bought a HDMI splitter. This doesn't seen to work. If I connect the...
The BT205 only has a HDMI Out so you need to connect both your BT205 and Apple TV to your TV either directly or through your splitter (depending how many HDMI Inputs your TV has).
You then need to connect either the Digital or Analogue Audio Port from your Apple TV to your BT205 and select the Audio Output from your BT205 as detailed on Page 27 of the manualat the link below.
http://tda.panasonic-europe-service.com/docs/2z4e3b157ez3z2a0dbz656ez706466z21z3703f025f4fa80ffdb9e5a7957895ca96b778f45/tsn2/data/ALL/SCBT205/OI/812908/rqt9445-b.pdf
This will give you the picture from your Apple TV to your TV via the HDMI and the Apple TV sound to your BT205 via the Audio Port.
Aug 04, 2011 | Audio Players & Recorders
The hdmi ports not whork whit my ps3 and my computer port
HDMI sends video from a component to a TV. It most likely will not send video from a PS3 to a Computer. Try connecting your computer to your TV via HDMI, and your PS3 to your TV via HDMI.
Jul 03, 2011 | Televison & Video
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
RCA R52WH73 Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
