Question about Samsung Office Equipment & Supplies
I have an ML1610 printer which has jammed - it failed to feed a sheet of paper. Now the red error light shows constantly. Is there a way to reset this?
If you open both the front and top flaps check theres no paper there and close them again this does the trick. Has always worked for me, anyway!
Posted on Nov 04, 2008
My samsung ml1610 printer has red light online/error, with the smart panel installed it shows paper tray empty..but it isn't empty, it is with good amount of papers, i tried to remove and install the...
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having http://downloadcenter.samsung.com/content/UM/200709/20070911095810078_English.pdf
Aug 29, 2011 | Samsung ML 1610 Laser Printer
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Brother HL-1435 won't print, thinks it's out of paper
Please see the following support articles that concern paper feed and jam problems on your machine: here, here, here,
If the Paper Source is set to manual you will receive this error. (See use guide pg.1-10) (here)
REmove the paper tray completely, open the rear access door and make sure there are no bits of paper anywhere. Then reinsert and restart the printer.... If all else fails, you could try a factory reset as described here.
Jul 26, 2009 | Office Equipment & Supplies
Jammed paper Samsum ML1610
Take down the front cover, pull the toner cartridge out and pull the paper to remove it. Check the plastic wheel that feeds the paper (use a flashlight). It has a rubber band that might be broken. Replace it if necessary.
Apr 10, 2009 | Samsung ML 1610 Laser Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
My Kyocera Mono Laser Printer is stopping between each page
call a service technician to clean the paper feed rollers... they aren't picking up the paper... this triggers the error so you have to stand there and manually reset the error and it prints...
Jan 21, 2009 | Kyocera FS-1030D Laser Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
175 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
