Question about Kenmore 98702 Stacked Washer/Dryer
Foot,frount of washing mechine,both sides will not go down, to level mechine
I have a sears kenmore model #11088762790,how do i get the foot levers down to level machine, in front both sides my e-mail address is philipberazen@sbcglobal.net
The dryer is causing thiner material clothes to get brown marks on them. Severe sqeeking when dryer is on.
Posted on Oct 13, 2008
My sears kenmore model#158.13160 presser foot bar isn't lifting up and down
If something isn't broken, most likely the machine is seizing due to lack of frequent and thorough oiling.
Wheel on right side that controls the needle up and down is very tight...
Aug 11, 2017 | Kenmore Sewing Machines
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
I need the s c r e w for the lever and the lever and nut that raises the foot presser. Where can I get this for my sewing machine Kenmore 158.18150.
Did you try going to sears parts.com and put your model number in it will show a picture of all parts
Apr 11, 2016 | Kenmore Dryers
WHERE CAN I FIND A MANUAL FOR MY SEARS KENMORE SEWING MECHINE MODEL NUMBER 148.14220
ebay
sewingpartsonline.com
sew4less.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
Apr 24, 2012 | Sewing Machines
I have a model 1315 sears sewing machine and have a new walking foot that doesn't seem to fit or allow me to stitch.......is there a fix? The walking foot is a kenmore brand and we thought it would fit...
I am sure that you realize that it has to be for a low shank machine and that you have to take off the presser foot and use the screw to clamp the walking foot on, and the fingers must be on the take up lever screw. Be sure to check the shank size.
Oct 21, 2010 | Vacuums
Water level won't fill past the lowest setting.
you may need to replace the level selector switch itself... if it has a reset option ( usually near the large side of the button, w/it plugged in, turn the switch all the way to reset, unplug the machine and then plug it back in. ) this has been known to work on occasion....hope this helps
Oct 18, 2009 | Kenmore Washing Machines
Decible level for a Kenmore model 16625691 ultra dishwasher
HI,
ACCORDING TO SEARS TECH SERVICE THE AVERAGE DECIBLE READING IS 53.5 DECIBELS
HOPE THIS HELPS. THIS IS ONE OF THE QUIETEST MODELS IN THE CLASS OFFERED BY SEARS.
Nov 12, 2008 | Hobart AM14-253 Free-standing Dishwasher
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Modified Lever Assembly
whitch lever assy are you talking about
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 98702 Stacked Washer/Dryer Logo
99 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
