Question about Brother IntelliFax-2820 Laser Fax
Stop Transmission Verification Report on Brother 2820
Whenever I fax and the line is busy or no response, it prints out a Transmission Report. But I do a lot of faxing and it's wasting insane amounts of paper. How do I get it to only print out the journal report and not the Transmission Verification Report?? Please help! email alysaunde@hotmail.com if possible. Thank you.
    Genius:
  • 2,120 Answers
It should be under the REPORTS section of the menus.
Step through the menus to turn off CONFIRMATION REPORTS.
Posted on Oct 01, 2008
Is is possible to go back two weeks to see a journal report on my brother mfc 9440 cn series? I didn't save a confirmation page and I need to see confirmation of a fax sent two weeks ago. Thanks
  1. Press the Menu key.
  2. Press the Up or Down Arrow key to select Fax and press OK.
  3. Press the Up or Down Arrow key to select Report Setting and press OK.
  4. Press the Up or Down Arrow key to select Transmission or XMIT Report and press OK.
  5. Press the Up or Down Arrow key to select the option you prefer.
    • Off
      Transmission verification report will print only if a fax transmission is unsuccessful.
    • Off+Image
      Transmission verification report will print only if a fax transmission is unsuccessful with a portion of the fax's first page printed on the report.
    • On
      Transmission verification report will print after every fax transmission.
    • On+Image
      Transmission verification report will print after every fax transmission with a portion of the fax's first page printed on the report.
  6. Press OK.
  7. Press Stop/Exit.
May 10, 2011 | Office Equipment & Supplies
HOW TO PRINT CONFIRMATION PAGE
You can use the Transmission Verification
Report as proof that you sent a fax. This
report lists the time and date of transmission
and whether the transmission was successful
(OK). If you choose On or On+Image, the
report will print for every fax you send.
If you send a lot of faxes to the same place,
you may need more than the job numbers to
know which faxes you must send again.
Choosing On+Image or Off+Image will print
a section of the fax's first page on the report
to help you remember.
When the Transmission Verification Report is
turned Off or Off+Image, the Report will
only print if there is a transmission error, with
NG in the RESULT column.
Apr 12, 2011 | Brother MFC 420CN All-In-One InkJet...
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
Press Menu/Set, 2, 4, 1.
-OR-
Press Menu/Set, 2, 4, 2.
You can use the Transmission Report as
proof that you sent a fax. This report lists the
time and date of transmission and whether
the transmission was successful (OK). If you
select On or On+Image, the report will print
Selecting On+Image or Off+Image will print
Note
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
is a transmission error, with ERROR in the
RESULT column.
1 Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Transmisstion Verification Report
Press menu/set, 2, 4,1. With the down arrow select off the press menu/set again.
May 17, 2010 | Brother IntelliFax-2820 Laser Fax
Need fax confirmation report .
1) Press <Menu>
2) Press Up or Down <Arrow key> to select "Fax"
3) Press <OK>
4) Press Up or Down <Arrow key> to select "Report Setting"
5) Press <OK>
6) Press Up or Down <Arrow key> to select "Transmission" or "XMIT Report"
7) Press <OK>
8) Press Up or Down <Arrow key> until the option you prefer appears:
  • OFF - Transmission verification report will print only if a fax is unsuccessful
  • OFF+IMAGE - Transmission verification report will print if a fax is unsuccessful with a portion of the fax first page
  • ON - Transmission verification report will print after every fax transmission
  • ON+IMAGE - Transmission verification report will print after every fax transmission with a portion of the fax first page
9) Press <OK>
10) Press <Stop/Exit>
I hope this helps!
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
Need a copy of faxed document to be included on printed verificat
print out a copy of the help page this should give you all the options and what keys to press to give you the option that you want
Jan 16, 2009 | Brother IntelliFax-2820 Laser Fax
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Fax busy, no response yet fax is sent ok
NG or poor line condition on the transmission report means that there is interference on the phone line.you need to double check the quality of the dial tone-if it static or clear.now,other interferences could be caused by other devices on the same line as your fax such as DSL modems.make sure first that you connect the brother machine directly to the walljack and try resending a fax.modem settings can be changed.e-mail me if you need that info
Mar 18, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
2,277 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
