Question about Epson Expression 1640XL Flatbed Scanner
Funky look to images
When scanning slides on the expression 1640Xl the images are getting a funky look to them.
Hi folks. I am the originator and have the solution to the problem. I feel a little stupid because I overlooked using a plastic insert/guide which is placed on the scanner, fitting on notches. It lets the scanner know to use the transparency device and provides a notch for film holder placement. It has been so long time since I used film ever since digital photography took over, I overlooked using this plastic insert. With it placed, I can scan film fine. Thanks
Posted on Mar 20, 2009
How to scan in pdf format?
In File Save Settings, you get a drop down box with the option to change the file format to PDF.
Jul 05, 2012 | Epson Expression 1640XL Flatbed Scanner
Epson 1640XL scanner with trans adaptor
just use scan feture in high quilty mode when yuor doing 8x 11 instead of instant transfer alot these epsons have isses did u dl the latest driver from website for it also www.epson.com
Jan 10, 2008 | Epson Expression 1640XL Flatbed Scanner
Red and yellow streaks appear in scans, always in the same location. The scanner was cleaned but the repair person could not find any problem with the equipment. Yet the streaks persist. How do I resolve...
execute a calibration to correct the wrong color:
  1. place your photo on the scanner, with a distance of 0.25 inch from the edge of the glass
  2. open Epson scan and select Professionnal Mode
  3. select the document source
  4. select the image type
  5. uncheck thumbnail then click Prevew
  6. crop the area of the image
  7. Click zoom to fine tune the area you see the streaks
  8. select the resolution of 72 dpi
  9. scan your photo
if the problem still not solved, you need to change the scanner unit , there are many dead pixels.
Dec 09, 2010 | Epson Expression 1640XL Pro Flatbed...
Stopped at start-up after months of no problems
Please trash the twain driver completely.
- Trash epson scan and epson scanner monitor from applications.
- Go to hd. Go to library, then application support. Trash epson scanner module.
- Go back to library. Click on image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on your computer name. Click on Library. Click on preferences. Click on the epson folder. Trash epson scan.
- Empty the trash and restart your mac.
Log on to epson.com. Install the epson11926.dmg.
Apr 28, 2009 | Epson Expression 1640XL Flatbed Scanner
Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Apr 17, 2009 | Epson Expression 1640XL Pro Flatbed...
3170 Epson scanner. Never a problem before, but
Turned off scanner. Rebooted computer. Turned on scanner again. Works fine now.
Mar 22, 2009 | Epson Expression 1640XL Pro Flatbed...
Epson 1640SU scanner, red line in all previews and scans
Most likely it is a spec of dust on the scanning sensor.  I recommend cleaning with a soft cloth and isopropyl alcohol.  More info here -  http://www.willshak.com/scanner/
Apr 29, 2008 | Epson Expression 1640XL Pro Flatbed...
Error message on Epson 1640 XL scanner
try to fix the usb cable or just replace it and reinstall the drive software disk. bye.
Sep 28, 2007 | Epson Expression 1640XL Pro Flatbed...
Epson Expression 1640XL Flatbed Scanner Logo
125 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
