Question about Acer Aspire 5610-4648 Notebook
Acer dvd drive not being recognised
Acer 5610 dvd drive comes up with
Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
    Genius:
  • 1,913 Answers
Go to device manager uninstall your dvd then try again
Posted on Sep 30, 2008
My acer aspire 5920 is not recognising usb when i plug anything in. Even hardware previously loaded. When I open webcam it also says driver not recognised but I have an integrated webcam
Go into your device manager and see if there is a yellow or red question mark beside USB HOST if so go look for the driver for your usb in your pc.
Apr 30, 2011 | Acer Aspire 5610-4648 Notebook
Sir, Am having acer aspire 5810T with windows xp OS. suddenly am not seeing the DVD drive in the my computer and the drive does not work. IN the device manager MATSHITA dvd RAM UJ862AS is...
Code 41 means the driver is either not loaded or corrupt.
Download a fresh driver from Acer and update the BIOS at the same time as that can give errors similar to this.
Dec 28, 2010 | Acer Aspire TimelineX 5820T-5951 Notebook
Dvd's not recognised but cd's work OK in the same driver
As per your problem description, it indicates that the drive has gone bad as it works fine with CDs. However, to confirm the same, I recommend you to perform the following steps:
* Remove the registry entry
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
* Replace the existing CD/DVD drive driver:
1. Click Start, and then click Control Panel.
2. If Control Panel is in Category view, click Performance and Maintenance, and then click System.
If Control Panel is in Classic view, double-click System.
3. On the Hardware tab, click Device Manager in the left pane. If a dialog box appears that describes permissions, click Continue.
4. Click the drive with the question mark next to it.
5. On the Action menu, click Uninstall. When you are prompted to confirm the removal, click OK.
6. Repeat steps 4 through 5 for any other drives with question marks.
7. On the Action menu, click Scan for hardware changes.
If the above steps doesn't resolve the issue, then it confirms that the drive has gone bad and needs to be replaced.
May 25, 2010 | Acer Aspire 5610-4648 Notebook
TSSTcorp CDW/DVD TS-L462D Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
What windows is this?
Who is the maker of the laptop?
  • Turn the computer off, remove the DVD drive and restart.
  • look for the drive in device manager
Windows xp – Start button>run> type devmgmt.msc
Vista/Windows 7 – start button> in the search box type devmgmt.msc
  • Remove or un-install the cd/dvd drive
  • turn off the computer
  • Put the drive back in
  • Restart the computer
  • Install your driver or allow the driver to install
If it continues to fail then either replace the drive or look in the component's properties, click the drivers tab and delete these drivers from windows system32 folder. You will need the windows installation disk to restore these drivers.
Jan 24, 2010 | Acer Aspire 5315 Notebook
Code 39 on DVD Philips SDVD8821
Download the latest driver from Acer site or phillips site.
Uninstall the device driver.
Reboot
Windows should detect new hardware and start the wizard. Point to your drver installation file and install the driver.
Reboot. this should fix the problem.
Apr 26, 2009 | Acer TravelMate 4220AWLMi Notebook
Philips dvdram sdvd8821H ata dvd drive not working
first see if you have all the neccesary drivers- i reccomend this program
http://www.drivermax.com/
if that doesnt work try usin system restore to a point before these problems occured.
thanks
CBZ
Apr 26, 2009 | Computers & Internet
MY LAPTOP DOES NOT RECOGNIZE MY DVD/CD DRIVER... CODE 39
you need to do
1) confirm the dvd driver works ok at other same laptop or find a usb dvd drive adapter to check it works well or not, the dvd driver damage if not
2) check the dvd interface pins (no damage or disconnection) on the motherboard, there is hardware problem that you can not see or heard any lights and driving sounds when the power on
Feb 06, 2009 | Acer Aspire 5610-4648 Notebook
LAPTOP DVD DRIVE WONT PLAY DVDS
ok " get a CD/ DVD cleaning disk , you pop that in and it will clean the lens inside, and they don't cost much, but do so much
good. happy movie watching
Jan 22, 2008 | Acer Aspire 5610-4648 Notebook
Acer Notebook 5610Z - Want XP Drivers
if your currently able to surf the internet with your vista os id suggest downloading the drivers for windows xp from the manufacturer onto a usb storage device like a thumb drive or external hard drive(hdd).
after you have all the drivers you'll need have:
the windows xp disk.
1)before you restart the computer insert the windows xp disk into the cd-rom
2)resart the computer
3)when the computer starts to post press the appropriate hotkey to enter the bios(usually f1,f2 or delete key) it'll tell you on the splash screen.
4)check the boot order in the bios making sure the cdrom is the first boot device. if it is press f10 to save and let the computer boot.
5)on the upper left of the screen you'll see (boot from cd)press any key(hit a key quickly)
windows xp will then start loading on the computer.
6)windows will look for previous installations of operating systems and display them on the screen
7)click on the partition w/the current os (when you click the os will be highlighted)
8)xp will give you the choice to install delete or format the current partition
9)choose to delete the partition
after you delete the partition windows will show a matrix of the hard drive without partitions (RAW SPACE)
10)highlight the raw space
11)choose create
Dec 07, 2007 | Acer Aspire 5610-4648 Notebook
Wireless adapter in Acer 5610-4610 is gone suddenly
Few ideas here, but obviously these are tricky questions.
Uninstall all software related to the wireless NIC, and then uninstall the hardware in device manager. Shut the machine down. Turn the machine over and remove all the little doors and look to see if the wireless NIC is an add-in card you can access. If it is, remove the retaining screw and remove it. Reboot machine, let it boot up, log in, and then shut down again. Reinstall the wireless card and close everything up again. When you reboot, you *should* get the new hardware found message, if you do, install the with the latest drivers and then reboot, and then check to see if the device is working properly in device manager (no warning messages). If it does not recognize the hardware, check in device manager if it has somehow put it on the unknown device list. If it has, try installing the latest drivers manually for the device by using properties tabs on unknown device in device manager.
If the problem is that the devices won't recognise and install their own drivers, you have a different problem which HP or whomever should solve.
Note, too, that if the laptop included custom control software for wireless connectivity (Intel, I am looking in your direction), the card may not be recognized without it, so install that software again, too.
Hope this helps...
Nov 13, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
Brian Sullivan
Brian Sullivan
