Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
My Ryobi 132r don't work
motor run on my 132r but the shaft do not turn. How do I fix?
THE MOTOR HAS PUSHED BACK INTO THE INTERNAL HOUSING. YOU CAN DISASSEMBLE THE HOUSING AND FORCE THE ELECTRIC MOTOR TO IT ORIGINAL SET UP BUT OVER TIME THE MOTOR WILL KEEP MOVING BACK. THE COOLING FAN WILL BEGIN TO GRIND ON THE HOUSING. THE PLASTIC, HOLDING THE MOTOR IN PLACE,WILL BREAK DOWN AND PUSH AWAY FROM THE ATTACHMENTS.
Posted on Nov 30, 2008
RYOBI ELT1100 ELECTRIC LINE TRIMMER DRIVE SHAFT PROBLEM
You can find it here
https://www.manualslib.com/manual/640551/Ryobi-Elt1100qfa.html
Oct 01, 2017 | Ryobi Garden
I have a Ryobi RLT30CESNB whipper snipper. Had it for about a year. The motor starts and runs okay. Just yesterday, all of a sudden, the head stopped spinning when I gave it some throttle. The motor still...
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 05, 2012 | Ryobi Garden
I have an electric trimmer plus 132r. Some times it works and some times it doesn't. When it doesn't and I play with the cord then the trimmer plus works. What do you recommend I do to fix the problem?
If you can get it going by "playing" with the cord, that is the problem. Either get a new cord or strip the one you have and find the break, repair it and go to work! Good luck...Lee
Aug 08, 2010 | Ryobi 15" Electric Factory Reconditioned...
How do I change string on my Ryobi TrimmerPlus 132r? I am unable to get the cartage off to replace the string. I have aligned the arrows but it will not pull apart
Send me $45.99 and I will give you the information in three easy lessons. But wait! I will even throw in an easy dvd and a twitter showing. All for the easy one time payment of $45.99.
Aug 01, 2009 | Ryobi Garden
Weed eater
Hi
check the following link
The idea is the same for all trimmers
http://www.youtube.com/watch?v=WFu66Q6J62Q
good luck
Jul 19, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi weed eater line keeps getting sucked back in
If you need a manual for ryobi 132r, I found it here - http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=pSo&tbo=1&q=ryobi+132r+manual&aq=0&oq=ryobi+132r+m&aqi=g1
Click on the link above and it takes you to a google listing. The top link is a PDF of a 15 page manual so that's the one you'll want to click on. It'll automatically save it to your desktop.
May 29, 2009 | Ryobi Garden
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
194 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
