Question about Lexmark X5150 All-In-One InkJet Printer
No color output
I have exhausted all solutions in help section, and still have no color output, what else can I do
  • Lexmark Master
  • 4,338 Answers
Here is a link to the service manual, look at page 2-13, you can do the Print quality checks.
Click on the link on the web page that opens up, it's about 1/3 up from the bottom of the page.
Download >> To download the file, please, click here ! << Download (<do not click on this link in this message)
Please remember to rate Techs who assist you for free :) Good luck, Joe
Posted on Oct 06, 2008
UndefinedI've checked a Panasonic crt color tv model TC-21fj20p, and I find a hard way to discover the cause of the problem until now.. The set has a good primary voltage supply. No problem with the IC...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Any short circuit at the horizontal output section circuit will shut down all the secondary SMPS voltages, as there is short circuit protection circuit to all Sony TVs.
Oct 28, 2014 | Televison & Video
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green screen
Thie is fault with color output section. Green color output section should be troubleshooted. Fault is said to be one color predominant screen.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older poststhere. The reason for this type of fault is described in detail.
May 19, 2012 | Toshiba Televison & Video
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our tv keeps changing colours to blue red and green
Your television have color problem.That symptom is cause of loose connection or cold solder in chroma section and color output driver transistor of CRT board of your television.You can fix that problem by resoldering the chroma section and crt socket section of your TV.first thing to do is open or remove the back cover of your TV,then you can see the crt board connected to picture tube.Resolder that parts,specially the color output transistor the red,green and blue driver.Resolder also the chroma section.You can see the jungle ic,thats the color ic.Make sure that there's no short circuit when soldering the PCB board.After the resoldering turn on the TV and check if color is normal.Thanks..
Aug 26, 2011 | Televison & Video
Picture is ruined by large amount of green and purple colour
Theres a problem in colour section of your television.The color trnsistor output is either shorted or open.There are three color output trnsistor,the red,blue and green driver output.Need to replace color output.
Jul 16, 2011 | Televison & Video
When i print toner status black color is faded as well as yellow and cyan, magenta showing white color, can you please give the best solution for this. by the way i am using hp 2600n. thank you very much.
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer.
Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600n Printer.
Dont forget to appreciate the solutions if I could have been of any help!
Dec 08, 2010 | HP Color LaserJet 2600n Printer
Phillips model # 27PT644 1/37 this tv has
I'll sell you the solution for $75, you bunch of crooked A*#es
Jul 31, 2009 | Philips 32PT6441/37 32" TV
HP J4680- change copy settings so printouts are fast draft
Change settings and copy from HP Solution Center
  1. Open HP Solution Center.
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Start icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
  2. Click Make Copies . The Copy window opens.
  3. In the Paper section, click A4 on the Size drop-down list.
  4. In the Start Copy section, click Black or Color .
  5. In the new window you can also change the copy settings
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
your problem is in blue video output circuit.
as you are seeing lines with blue  color
those lines are called retrace lines.
please check
  • supply to blue video output ckt.&blue video output transistor.
  • loose crt base or crt base connector.
  • componenrs related to blue video output section
  • blue signal coming to red video output ckt from signal processor.
  • at last but rare cases crt weak.
  • hopr this will help
good luck
Oct 16, 2007 | Haier HTF27R11 27" TV
Lexmark X5150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
