Question about Sanyo 24KS62R Cool Mini Split Air Conditioner
Heat controller mini-split air conditioner
Compressor on brand new mini-split just hums,condenser motor runs fine
  • Anonymous Mar 18, 2014
    mini split air
  • Anonymous Mar 25, 2014
    compressor run all the time,
    relay contacts on the electronic board is broken
    Scholar:
  • 147 Answers
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Error code Ch 07 ?
Ch-07 Splits = Compressor Over Current or discharge pipe temp high.
Reasons: LC condenser block-Clean it.
Less rpm of fan motor.-Replace capacitor.
Discharge temp sensor defective -Replace it.
Hope, is it helpful?
Dec 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have C7 error on an LG 9000 heating and cooling unit new installation. I dont have a manual to help with the code. Please Help
C7-Split compressor over current. Check condenser. If full of dust, clean it. Check rpm of fan motor. If less rpm replace capacitor.
Oct 01, 2010 | LG LS-L1210CL Mini Split Air Conditioner
CONDENCER AND EVAPERATOR FANS BOTH COME ON WHEN CALL FOR AC. THE COMPRESSOR HUMS BUT WILL NOT START. UNIT HAS RUN VERY GOOD. THE COMPRESSOR WILL NOT COME ON UNLESS IT HAS BEEN OFF FOR 24 HRS.
It's either a bad run capacitor, start capacitor or start relay. More than likely if you have a thermostatic expansion valve it's a Start capacitor or start relay.
Jun 29, 2010 | LG LS-K1830HL Heat Cool Mini Split Air...
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Rudd 2 ton 10 S
The small copper line should not be really hot its supposed to be carrying liquid refrigerant which has already had the heat "pressed" out of it by the compressor and carried of by the air flowing over the condenser coil. This could indicate a few things; that your unit is overcharged, you have a mismatched evaporator coil and condenser, an ineffective condenser fan motor or a clogged condenser coil and as a result your compressor is shutting of due to an overload condition from the building heat and back pressure between the compressor outlet and the evaporator inlet.
First make sure your condenser is clean and that adequate air is flowing over the fins of the condenser coil. Then be sure your equipment is a matched system. A indication that your condenser fan motor is not at speed is slow starting a humming sound and excessive heat. In my experience this complaint is generally the result of a bad condenser fan motor that over heats and shuts of after a short period and the build up of heat in the liquid refrigerant line of course trips the compressor overload circuit- which by the way usually takes hours to reset. I hope you've already resolved this, but in case you haven't......
Aug 01, 2008 | Ruud Matching Split Air Conditioner
Sanyo 24KS62R Cool Mini Split Air Conditioner Logo
597 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
