Photocopier not copying
My Toshiba T-120PE is only producing very very light prints. I have put in a new toner and changed dark/light but nothing makes any difference.
    An expert whose answer gotĀ voted for 100 times.
  • 87 Answers
Posted on Dec 18, 2008
How can I solve Toshiba e studio 257 photocopier toner problem?
Try turning the main power switch off or disconnect the power, wait 20 seconds then turn back on again. This should reset the toner.
Aug 29, 2016 | Toshiba Office Equipment & Supplies
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
New cartridge and prints very light
Ithink you might need a developer change.
May 04, 2010 | Minolta bizhub 200 Copier
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Problem on Toshiba e-studio 45
I beleive that if there is a problem with the primary you will only get a blank copy not black.
the problem is most likely your Seperation ***'y or the drum.
1- either the sep/***'y is shorting out causing the paper to rise against the drum and putting too much toner output, or the drum has not been adjusted correctly. Did the tech adjust the new drum to the machine? there is a procedure you have to do everytime you change the drum.
Aug 04, 2008 | Office Equipment & Supplies
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
81 people viewed this question
