Question about Epson Stylus Photo R300 InkJet Printer
Basic printing, not photos
After paper ejction problem, I cannot default to basic text printing. I do not wish to print photos. All settings are now for photos.
I do not have manual so need to know how to print basic.
    Problem Solver:
  • 4 Answers
Well the paper issue should be resoved by going in through the control panel to get to the printers section where it has a button (once your on the R300's settings) where you can reset all the printer options then after that in the document in the printer settings if you go to the print screen and click the properties button (right next to the name of the printer) when the properties section come up under the quality options it should have five options, one of which is labeled text, click that one and print it should come as a regular document (you might have to re-reset the options in this screen as well before printing the document)
Posted on Oct 17, 2008
My printer is stuck on photo paper how can I get to A4 plane paper
You did not really give much information to go on (like what make and model of printer (Epson, HP, Canon, Brother, etc.) nor the operating system, etc.) BUT assuming you are using Windows and an Epson printer, then go into Start - Control Panel and to the Printers section. Right click on your printer, left slick on Properties and then change the type and size of paper to what you want to mostly use and click OK. By doing that, you set the default paper and size - you can also set the type of printing like, say, text and graphics. When printing anything else, like say photos on gloss paper, just change when you want to print using the different setting. It will only be used for that print job as will always default back to what you set as described.
Feb 25, 2015 | Office Equipment & Supplies
Cannon MP600 will not print accurate photo colours
First clean and align the printer correctly.
You will need to ensure that you have selected Photo Glossy Paper for best results. You will also need to adjust the gamma settings and also play with the colour saturation controls to achieve a good colour balance that you are happy with.
Try printing a basic colour additive chart and comparing screen against printout and adjusting settings as required.
http://en.wikipedia.org/wiki/File:AdditiveColor.svg
http://upload.wikimedia.org/wikipedia/commons/archive/6/67/20071203133356%21CIE1931simple.png
Also have a look at myPANTONE colour splash to get the definitive Pantone Colour Mixes at
http://www.pantone.com/pages/pantone/pantone.aspx?ca=24
or use a paint tool or PhotoShop etc to create solid colour blocks of basic colour to compare against.
Nov 06, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Printer always uses large black & runs out, cant isolate other
The BK5 is for black text only. The other black ink is used for shades of black/gray together with the three basic colors in printing color photos. You cannot use it to print black text.
Jul 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Right color balance standard print setting, but wrong in high rez
Hai,
before giving the print command clear the previous notepad given by the printer by manul and restrat your printer and give print command
Dec 25, 2008 | Canon i9100 InkJet Photo Printer
How to print picture using 10x15cm photo paper? usually the pictures printed only half
Hi
1) when you begin to print have you set the paper size to the size you require ?
2) If not when you press print a grey box appears to comfirm printing yes!
3) press properties top right of page
4) open tab basic
5) Alter paper size to correct size
6) Also check your paper setting on the programme you are using to print from,
7) Also that the orientation is correct "portrate or landscape"
grandpaben
Nov 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
Borderless printing kodak 5500, clear coating business cards
The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
  1. Click File , then Page Setup .
  2. In the Page Setup dialog box, click the Paper tab.
  3. Under Paper Size, select the appropriate borderless paper size.
To select borderless printing in the printer driver, follow the steps below.
  1. In the application, click File , and then click Print .
  2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
  3. Select the appropriate borderless paper size.
HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lines on a photo when printed
The print quality usually depends on the program you're using to print them on your pc.
Your camera only ever sends photos to your printer, so the best settings are already selected by the camera and it's built-in photo program.
Your printer doesn't 'know' whether your printing a document or a photo, so the settings for each program on your computer are basic (known as default settings), and need to be changed by you to get the best from your printer
Find the settings that let you alter the printers options (in Word, it's FILE \ PRINT \ PROPERTIES), and make sure the printer output is set to maximum quality, and that photo paper is selected as the paper type.
Some options such as 'maximum quality' only appear when you've chosen 'photo paper', and some printers (such as the ip4300) have seperate options for gloss or matte paper, so go through all of them until you see what you need.
Hope that helps :)
Oct 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Epson Stylus Photo R300 InkJet Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
