Question about RCA RC5240P
RESET DVD PLAYER'S PARENTAL PASSWORD
HOW DO YOU FIND THE FACTORY RESET BUTTON IN THE MENU? THERE IS NONE!
  • 'Steve Haberman
    'Steve Haberman Feb 22, 2009
    dvd player requests password we never entered one. please help
99999
Posted on Feb 23, 2009
WORKED THANKS
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
Unlock instructions for Toshiba dr570 DVD
Hello
Turn on your DVD player and television. Select the appropriate input source for your DVD player on your television.
Press the "Setup" button on your DVD player's remote control to display the main menu.
Navigate to the "Rating" menu option using the "Down" button on your remote control. Choose the "Parental Control" item by pressing the "Right" arrow button, followed by "Enter."
Enter the parental control access password using the numerical pad on your remote control, followed by the "Enter" button. If you did not previously setup a unique password, enter "8888" when prompted for the password.
Press the "Enter" button to display the parental control rating menu. Select the "8: Adult" menu selection by pressing the "Up" or "Down" directional buttons on your remote control, followed by "Enter." Press the "Open/Close" button on the front of the DVD player to complete the process.
Nov 21, 2010 | Toshiba DR570 DVD Recorder
Parental controls set, no password known
Check to see if there is a reset to factory settings in the menu or a small hole on the case which you can use a pin to push a small button in side which is used to reset your device to factory settings
Aug 29, 2009 | Panasonic Televison & Video
Password unknown
  1. Press power on from a cold start with no disc in the unit.
  2. Press the STOP and PLAY buttons simultaneously on the front panel for three seconds. “All setup value will be reset to factorysettings. Your player will be shut off.” will appear.
  3. Press the MENU button on the remote control to select the Parental Mode. The Parental Mode is now unlocked as indicated on the display.
  4. Press the DOWN button to select Parental.
  5. Press ENTER and the Password Check display will appear.
  6. Enter the default password of “9999”.
  7. You can now set your rating level and change your password to a new number.
Mar 13, 2009 | Samsung DVD-N501 Nuon DVD Player
Dvg-4000s
I didn't have that problem before but you can try this:
Press EJECT,SETUP,STOP,I<<(PREV), >>I (NEXT) "FACTORY CONTROL PAGE" menu will apear on the screen.You should find here something like factory reset by scrooling with direction buttons on your remote.When you find it press play and setup
Sep 13, 2008 | Daewoo DVG-4000 DVD Player
Parental control
i posted the site on tips and tricks where you will find the manual.parental control 8 is the default setting. the factory setting password(enter this in the new password bar)is 3351 and youll have to take it from there.it seems you have a password on your machine you can change it to your own with the factory setting number.good luck, SLEWEY.
Feb 16, 2008 | Cyberhome CH-DVD 300 DVD Player
New - parental lock LOCKED and password will nowr work can't use DVD
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
Dec 06, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
RCA RC5240P Logo
1,074 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
