Question about SmartDisk FireLite 80GB 400Mbps FireWire IEEE 1394a External (FWFL80FT) Hard Drive
I have aSmartDisk Firelite FWFL80-N, the firewire ports are producing a weak connection connection
We have to hold the cord to retreive files. We were told to get a new enclosure case. All I could find was a 2.5 IDE USB case. It just makes a high pitched noise and doesn't show up on the lap top.( Intel Macbook Pro 10.4) Any recommendations as to what brand replacement case will work or what specifications to look for?
    Problem Solver:
  • 29 Answers
Problem may not be the case. If you holding the cord the port that the cord hooks into is going bad. Do the cheap repairs first, check the connection or replace the cable first then the case.
rmatheson@wowway.com
Posted on Sep 30, 2008
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
I have a Firelite Smartdisk External 60G hard drive - Model #FWFL60-N which I bought to back up my previous MacBook. It only has FireWire outlets and cable with only FireWire ends - no USB port...
Hi Selina It was a big mistake for Apple to omit the FW port on the white MacBook. The problem you hilite is the reason I don't recommentd the macbook to any of my clients. However, the problem is solveable - although you may/will have to do some breaking and entering.
There is no cable adaptor - nor will there ever be, the protocols are so radically different that they can never talk to each other.
The simplest option is to connect your drive to another mac that has got FW (800 or 400 - it doesn't matter as long as the cable will connect the two units) then use file sharing to transfer the conent of the drive to you MacBook either by ethernet (preferable) or by wifi (much slower).
The breaking and entereing option imvolves opening up the firelilte and removing its HD (it's easy) then get a unit like this Overview or this http://www.maplin.co.uk/sata-hard-drive-usb-docking-station-222999
There are other much cheaper units and they all work fairly well. I have several as I'm up against your problem regularly
Apr 01, 2011 | Computers & Internet
Need to purchase cord that will allow me to go from firelite to usb for new mac computer
Along with the Firewire port, there should be a standard USB 2.0 port on your drive. In that case, any standard USB cable will do. If for some reason there isn't a USB 2.0 port (?), you can purchase
a USB/Firewire adapter for about $1.50 at Monoprice.
Jan 08, 2011 | FireLite (USBFLB80) Hard Drive
MY COMPUTER DIED. HOW DO I TRANSFER THE FILES FROM MY VERBATIM SMARTDISC FIRELITE 160 GB, USBFLB160' TO ANOTHER COMPUTER? THANKS...........................JOHN NICKERSON
It depends on how you copied your files to the SmartDisk.
If you used the "normal" method of copying files/folders in Windows, then just connect it to the new computer.
If you used some "backup" software from Verbatim to write "backup" files,
then you'll need to install that software on the new computer,
in order to retrieve from those "backup" images.
Nov 13, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Hi. I have lost my adapter and connectors to connect my smart disk HD to my Macintosh power book (g3 model). The model # on my disk drive is FWFL80-N. Has another # which is JH7X04. Where can I find...
You could buy a disk-drive-to-USB adapter, and connect the "bare" disk-drive to a USB port on your computer, and then copy all the files onto your computer.
See: http://cgi1.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=190391564434
for under $5.00 for such an adapter.
Or, you could spend about $40 to buy a brand-new enclosure & AC-adapter & cable that is "empty", and then you could "transplant" your 40GB disk-drive into that enclosure, without losing any data on the disk-drive. Then, copy the files, and then remove the disk-drive, and purchase a new, larger, disk-drive, and install that into the new enclosure.
Given that your disk-drive is "only" 40GB, it's probably getting old, and is "out-of-warranty", and thus should be "retired" before it completely fails.
So, the best solution would be to buy a brand-new, much larger, external storage device.
Nov 07, 2010 | SmartDisk FireLite 40 GB Hard Drive
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
Firewire port problem
Just buy new firewire then put OLD hdd that come with first firewire and put in new firewire!Let me know if u got help!
Mar 11, 2008 | SmartDisk FireLite 40 GB Hard Drive
Firelite smartdisk
sounds like the firewire drivers are corrupt try and re-install drivers and if that did'nt help take drive to a friends house that has firewire on his computer and try on his if you get the same it's got to be sent off to be repaired and hopefully you can get files back thats why i take 2 copys one on one hdd and another on another and if one goes down I've got a back-up to fall back
Aug 10, 2007 | SmartDisk Crossfire Desktop (xf160f) 160...
Computers & Internet Logo
559 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
