Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
I have snow and not picture.
I've called the cable company and it appears everything is fine and it is my TV. At first I had a problem getting it on channel 3 and finally when I did it still doesn't work. It comes on with Ant 3 stays on 5 seconds and turns dark. There is also no sound. Not sure what to do.
Please help. Thanks.
  • 4 Answers
I'm afraid you may need to consider the fact that your EDTV may have failed in service (broken).
Posted on Jan 01, 2009
No picture model Toshiba TV model #32c100u2 get
Does it have a DVD player Combo unit ???
Aug 16, 2013 | Toshiba Televison & Video
Hi-\r\n Thank you for being here- We were watching our Sharp Flat Screened TV, beautiful nice picture. We noticed when we hooked the cable up for Direct TV in our new home, the input connection point was...
With Direct TV, you should use the video input (composite video- yellow/picture, red/right stereo, white/left stereo)
OR
component video- (green/video, blue/video,red/video white/left channel stereo, red/right channel stereo)
the antenna connector should never be used anymore unless connecting an outdoor antenna or VCR.
if one of your input connectors is damaged, it is not likely that is will be repaired without replacing the entire circuit board (expensive!!!).
just use a different "input"- there are usually at least 3 on most TV's
Apr 12, 2011 | Sharp Televison & Video
Hi, My friend has a Toshiba 65h84 Rear projection tv that has bad picture. when turned on it shows some snow effect but pink instead of white. when we connect the cable you can see distorted video on the...
Chances are you have a defective hyper module. The symptom with this problem is called piecrusting and appears as a squiggly and distorted picture, usually worse at the top. It may dissipate after 20 to 30 minutes as well. This module has been out of production for a few years but some regional companies will rebuild it for around $125.
Bill W
integrityhomeworx.com
Mar 14, 2011 | Toshiba 65H84 65" Rear Projection HDTV
Dynex TV picture disappears to snow after a second
I bought this TV and had the exact same problem, I tried everything i could think of and so did Geek Squad but nothing worked. We called Best Buy to see about a return policy and the manager told us that the brands Dynex and Insignia do not work with certain cable companies, one being Comcast. Call Best Buy and ask if your cable company will work with the brand. My suggestions are to either return the TV and search for a new one, I did this, OR you could take a DVD/VCR player and connect the cable from your wall to the DVD/VCR player. Then use the red, yellow, and white wires to connect the TV to the DVD/VCR player. Put your TV on the proper input and cable will work fine, because you will see the picture from the player not directly from your TV. I hope this helps, if you need any further information just ask.
Apr 15, 2010 | Televison & Video
VCR will not show picture or menu on TV after power outage.
Hate to say this, but when power outages occur, things like vcr's are the first thing to fry. But if you feel that the vcr is fine as far as powering up, then unplug it from the wall socket for 30 minutes or so, plug back in and see results.
Apr 13, 2010 | Televison & Video
"snow sound on all but two channels" but perfect picture
in the menu setup there is an autoprogram that sets the channels.
is there not an issue regarding analog signals?
Sep 14, 2009 | RCA F27442 27" TV
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
KV35540 Sony Trinitron
pls check the antina or the cable line or the cable plug or call the tech.
in the tv tunner foulty
Jun 07, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
27 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
