Question about Maytag Kitchen Ranges
Maytag CRG9700AAW range flashes f2 Fault code.
  • 146 Answers
SOURCE: maytag range shows fault code F14
You have a problem with your oven temp. sensor. Remove it and check it at room temp. It should meter out at 1 to 1.1K ohms. If it doesn't replace it.
Posted on Dec 29, 2007
  • 2651 Answers
SOURCE: Maytag Gemini Range fault code
relates to faulty oven sensor, repalce oven sensor in affected oven
Posted on Mar 04, 2008
SOURCE: oven fault codes
icon1.gif imported post "The best that I can determine from the fault codes is that the *ribbon* on the range electronic control----is not tight enough. Turn off curcuit.
If you unplug the range and remove the rear panel behind the electronic control.
There should be a tape-like ribbon that goes to the circuit board.
This ribbon is problably not snug enough at the connection.
I've read about servicers tearing off the cover of a pack of matches and inserting it into the connector to improve the fit. This can only be done by pulling the ribbon out and looking at it to see which side is bare metal (basically flat wire) and which side is insulated or non-exposed wires. Obviously the matchbook cover must not be pressed into the side of the ribbon that connects with the pc board wiring.
John" I followed John's advice and it worked. I, a 33 yo female, removed the back panel of the stove, found the ribbon (along the back/side of the display looped and connected to the panel), detatched it, cleaned it with an eraser (suggestion from another blogger), and reattached the ribbon snugly (locked in by a plastic thing). I don't know if it was just loose or needed cleaning but it was easy to do. Sears would not even tell me what the code meant and they were going to charge me $65 for a technician to come out. We do have an electric stove instead of gas, so I am not sure if it will be any different. Good luck. Dana
Posted on Apr 28, 2008
SOURCE: maytag error code f2 on
F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor
Posted on Jun 27, 2008
  • 241 Answers
SOURCE: f2 fault code on hotpoint
Unplug it and check see if this helps wait at least 5 minutes
They have a internal memory
Posted on Aug 28, 2008
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ... > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ... > Manage My Life > Questions
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it '"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
I have an old maytag gas range model number CRG9700AAW, that beeps with an "F7" on the display, any idea what this alarm is?
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Jul 29, 2011 | Maytag Kitchen Ranges
Maytag electric range, older model. What is a beeping, flashing code F2
F2- oven too hot. usually due to a bad oven temperature sensor. they sense the temperature of the oven by changing resistance, and can keep the element hot, or turn it off.
Jul 06, 2011 | Maytag Ovens
My ge xl44 gas range, installed in 2000, turns off and flashes an f2 code occasionally. Can you give me the reason?
F2 means: For an unknown reason, the oven temperature has exceeded a preset threshold.
G.E. recommends you try this:
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737
Here is the fault code guide link:
May 20, 2010 | GE Kitchen Ranges
Washer flashes f 1 and will not start
The range/stove fault code page....
My Range is flashing a "F" something.....what does this mean??
Some terms used on this page...ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction. Oven temperature sensor - What a common sensor or temp sensor looks like.
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic by Make and or problem...hope you find this helpful :-)
A tip for the famous F1 fault code entr_anm.gif The biggest Fault Codes list that I am aware of! What does an oven temp sensor look like?Some info and tips on oven temp sensors
Newer 4 digit fault codes - Maytag, JennAir, Magic Chef Newer Frigidaire fault codes new25.gif Some newer GE built in oven fault codes are here. Newest Hamilton built GE clock fault codes are here. I have some of my own hand written fault codes, here and some more here. The Maytag Gemini range fault codes are on this page. The Maytag Accellis range codes are on this page. traffic_record.php?lc=024041009290002517 A tip:The supplier recently reversed the display areas for the clocks. Therefore you may find an F1-E0 code or E0-F1 code depending on the model. They both mean the same thing, and depending on the model determines the code reference, and location of the F code. Different manufacturer of the clocks caused this.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Maytag stove with f7 code
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Dec 19, 2008 | Maytag MER6772 Gemini Electric Kitchen...
F1 fault
Here are the fault code for GE:
Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
Kitchen Ranges Logo
91 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
