Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Ice maker I just recently replaced the ice maker dual water valve on my hotpoint side by side. The valve is located on the back and bottom of the hotpoint. The housing was leaking. After I changed the valve and replaced old water lines. I turned the water on , no leaks, but, the water would not stop running into the ice maker . I thought that I might have switched the connnections to the solonoids so I reversed them . Same thing, water would not stop. I did notice that my water line was making a humming noise when I turned it back on. could there be air in the line effecting the water .
  • 65 Answers
Disconnect the power wires from the valve, if it still fills with water, I would say you have a stuck valve. just because its new, doesnt mean its going to work.
Posted on Jan 27, 2009
Every time we turn on our ice maker it leaks on the floor and ice bulids up on the floor of the freezer. it makes ice fine and the water dispenser works fine. we have replaced the water line thinking...
Most times the leak is caused by a defective dual water control valve but in this case it is obviously not the problem. Make sure your refrigerator is level front back and sides. If the problem is not cause by being out of level I want you to look for cracks in the W10190929 Ice Maker Mold and Heater assembly. Also where the water pours into slot 22 below
Anything is possible so you may need remove the ice maker so you can examine it closely if impossible to see while inside the freezer. Complete 4317943 Ice Maker Assembly or 2188542 Dual Water Control Valve Let me know if you have questions, Thanks Sea Breeze
Nov 17, 2012 | Whirlpool 19.8 cu. ft. Side-by-Side...
GE bottom freezer ice maker not working
Remember there are two sides to a dual water control valve, the water to dispenser side and the side that feeds the ice maker. Replace the WR57X10094 Dual Water Control Valve and I think you will be good to go on ice, Thanks Sea Breeze
Jul 02, 2012 | Refrigerators
Ice maker stopped making ice
The ice maker not making ice.In this case the water passing line and water valve needs to be inspected.--
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Hotpoint HSM25GFRSA
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
Ice maker makes ice then water dripps and freezes
water valve not working properly needs to be replaced ... located on bottom back nof fridg
Aug 11, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Does anyone know how to fix an ice maker?
When the ice maker calls for water it pours for about 7 seconds if more will overflow and drips into tray , but the most common problem is the dual valve that leaks even after ice maker called for water (this valve is located in the back of the fridge at the bottom where the water line is hooked up.)
Aug 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
105 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
