Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Aig No siginal
Comes on says aig in corner then say's no siginal and turns off . Checked the cable box is fine.
  • 4 more comments
  • loriss Sep 30, 2008
    never hooked up to vcr or dvd cable only
    checked cable wires box is hooked up to two TV's, other tv is working fine
    It says RGB no signal tried to hook up dvd same thing? would the TV have a reset butten?
    done that no luck
    No still doing the same
  • loriss Oct 01, 2008
    Called Tec Support Free 1-877-698-4946 Free and fixed it
  • 2,071 Answers
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Oct 01, 2008
  • Vizio Master
  • 19,396 Answers
Check the input selection settings with the remote. The TV have more than one input.
Turn on receiver box, then change input usin the remote, and see if you get signal.
If it does not work test the box on a different tv, to see if the cable box is faulty.
Posted on Sep 30, 2008
    Master:
  • 479 Answers
Swap the cables and try and if it doesnot work after that then it is the problem of the socket of the tv in which you insert the pins . sometimes the connections inside the tv gets loosened up so cold soldering it will solve your problem definately .its a very common problem so nothing to worry.
  • 6,487 Answers
Try to reset the unit, unplug first the power for about 30 minutes to an hour then when you plug thepower to the unit press the power button for about 15 seconds and hopefully that will reset the unit...
Hope that helps..........
  • Mark Gil
    Mark Gil Sep 30, 2008
    IF all solution failed there's a possibility of a bad parts on this unit that needs to be replace so if its still under warranty you may atke it to a servcie center and have it check there.......
  • 1,879 Answers
Swap the cables then (connect the known working connection from the other TV to the non working one).
  • 958 Answers
Kindly check the cable itself. sometimes the pin in the center is not long enough to touch the center of the socket to make a connection. make a continuity check of the cable ground and center wire.
check also if you have signal from the box by using another tv.
tnx 4 using fixya,
drcool
    Scholar:
  • 148 Answers
Hi THERE,
I WOULD LIKE TO KNOW THE MODEL# AND THE MAKER OF YOUR UNIT..
HAVE YOU TRY TO WATCH ON THE TV IN THE VIDEO MODE?
KEEP ME UPDATED ON HERE.
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 30, 2008
    IF IT'S POSSIBLE TRY TO HOOKED UP / CONNECT YOUR TV WITH A DVD OR VCR. THIS WE WILL KNOW IF THERE IS A PICTURE PROBLEM ON THE TV.
    HERE AGAIN
Cluster problems
Check fuses first. Also check all pcm harness connections
May 10, 2014 | 1997 Audi A6
Cluster problems
I had a problem like that before with ford focus (apparently common fault) what I did was unscrew cluster from dash board remove main board, brushed it down with soft brush and gave a spray of wd40, put it back and have never looked back. Garage was gonna change me over 600 to replace. Luckily I found solution on Internet hope this helps.
I'm looking for a contact number for Chartis Life Insurance
Chartis Life is now AIG (American International Group, Inc.). There are several telephone numbers for them, but you might start with (877) 867-3783. That's the number for their Accident & Health customer service.
Nov 28, 2013 | Cell Phones
Where can I purchase airbag sensor 2 for a 2005 gmc serria 2500
at your local dealer. any time you replace parts it is wise to use oem quality replacements there is only 1 impact sensor on the 2500 it is located around the front of the radiator support rite in the middle
Oct 11, 2012 | Cars & Trucks
Aig bag light flashing
It should flash a code to tell you what is wrong with the system. Most of the time it will end up being a burnt out bulb for the system. Count the blinks and then wait for a minor pause and count the blinks again. Should give you a 2 digit code like 27. Google it online with your year make and engine and it should come up or call the dealer. Post it here if you cant find the answer
Nov 24, 2011 | Ford Crown Victoria Cars & Trucks
I need to remove the oil pan because it has aig crack and hoping to see if i can weld it shut.
might not be a good idea to weld it cause it might crack more its best to replace it
Aug 22, 2011 | 2001 Ford Windstar
AIG function is on and I can't get it off
If you mean "ALG" then your calculator is set to algebraic notation. To switch to RPN, press MODE then 5.
Feb 17, 2011 | HP 35s Scientific Calculator
Cant figure how to replacelightswitch
detach battery
take off steering wheel/aig bag
take off column covers
then there are wo upper screws and one lower
take off the switch from the column and unplug it
Mar 26, 2009 | 1996 Chevrolet Cavalier
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
99 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
