Question about Dell E172FP 17" LCD Flat Panel Monitor
Help me please
I have problems with mz monitor dell E172fp
when turn my PC my monitor screan is black and on power button blinking grean.
what do you means about my problem
sorry my english is not so good
tx
BEST REGARDS
Jusuf Jelec
Sarajevo - Bosnia - Europe
jelecj@yahoo.com
  • Anonymous Dec 02, 2008
    Hi have the same problem. When I press the monitor's power button the screen is normal for 1 sec and you can see the WIn XP log-on screen but then the monitor goes black. The power button flashes green. If you press and hold the power button the monitor does turn off. When pressed again it does the same exact thing.
  • Anonymous Jan 06, 2009
    I have the same issue. If I disconnect the signal from the CPU the light turns amber. This happened after my kids turned the monitor slightly ( 20 degrees). I have seen this question a lot but no answer yet. Where can a person take a monitor to have it checked? I live in a fairly small town!
  • 555 Answers
You got a common problem caused by bad transistors. Here is the solution:
http://josepino.com/?howto-repair-dell
I do not recommend you to follow the instructions if you don't have previous electronics repair experience.
Posted on Sep 04, 2009
E172FP (Black) 17 in. Flat Panel LCD Monitor: Dell monitor problem, its the power save mode agai...
First, try it on another PC, check or try another VGA cable, if it still does not work then you need to open it up. Dell monitors are known to have bad solder connections, bad caps. See my photo albums of failed Dell monitors to get some idea what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 18, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
What could cause a dell flatscreen monitor to go
Probably a bad power supply in the monitor. One of these days it will go black and stay that way.
Dec 08, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Press power on... screen flashes on (blink), then goes blank and power button flashes
dpelrod727, Yes, the "switch-mode-power-supply" is in "partial" or "full" SHUTDOWN mode. Reconnect E172FP to a fully booted KNOWN good PC with the win-desktop as the displayed screen. Check with flashlight to see if your LCD panel is both BLACK and BLANK, or just BLACK by holding a bright flashlight 1" from screen at different angles even though the screen appears to be blank. If very faint image of desktop is seen then your SMPS is still half alive. Here are your options in either case. 1. Trade in for new. 2. Try Dell for a cash+old swapout for a Refurbed unit. 3. Check out www.ccl-la.com/badcaps, www.badcaps.net, www.lcdparts.net, and YOUTUBE long video clips dealing with LCD monitor disassembly and LCD repair. could be helpful in making decision on what to do. I'm 12fixlouie If this was helpful rate on fixya.
Nov 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell E172FP, monitor blinks then goes blank or black
This is a known problem of the Invertor board.If you are technically able you can open the monitor and resolder transistors 2sc5707 as also all pins of 4 yellow invertor transistors that you can see near the backlight connectors.
Samir.
Please rate the solution and provide feedback
Sep 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell computer windows xp pro. samsung syncmaster 731b cannot install right. says comp. cannot support default monitor installed ,
I need help monitor went blank and when I try to turn it back on it only blinks at the power button. took it apart and everything looks ok.
Mar 26, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Apr 28, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
193 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
