Question about Panasonic DVD-S53
Unlock region code for Panasonic DVD S53
ONly plays in Region 4 but have dvds for 1 and 2 that we can't play. I have a code for Phillips DVP3020. Will this work?
5 Suggested Answers
bluegreenash
  • 657 Answers
SOURCE: Multi region code for DVD
it appears that this player requires a modified remote control to unlock the other regions (some use plug in modules or hard chipping or service Discs, it really depends on the restrictions of the player)
here is a link to a site that supplies the remote you need, although I'm sure that there are other sites that supply this
http://www.dvdcodes.net/prods/panasonic/pan70-79.php
Posted on Nov 03, 2007
zair
  • 82 Answers
SOURCE: Panasonic DVD-S27 Region Free setup
A special service remote is needed to change the region.
Posted on Apr 06, 2008
rizla
  • 1463 Answers
SOURCE: Panasonic dmr-eh57 multi-region unlock code
see this any luck here dvd
riz.
Posted on Aug 01, 2008
  • 3 Answers
SOURCE: Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
Posted on Jun 13, 2009
SOURCE: How can I unlock unlock PANASONIC BLU RAY Recorder
how to unlock panasonic DMR-BW850
Posted on Apr 29, 2010
I have a Phillips DVDR70 player. It only plays dvds bought in UK. I have some dvd's I got from USA and can't play them. Is there any way to overide the operating system which will allow the Us dvd's to...
You need to unlock the player before it will play discs from other regions. UK has region 2 discs while the US has region 1.
Search on Google for your DVD model and unlock code.
Dial in the code using your remote and you should then be able to play any region discs from around the world.
Apr 30, 2010 | Philips DVDR70 DVD Recorder
Christina Weate
Jun 11, 2009 | Televison & Video
Won't play Region 2 PAL dvds
Here is the code..
1. Power on
2. Tray open
3. Push MENU
4. Push 8888
5. Push Display
6. Push in desired region 0-6, (0 is ALL REGION )
7. POWER OFF
8. REGIONFREE!!
Jay
May 20, 2009 | Coby DVD-257
Make dvd player into muilt region so it plays all dvds
hello.go to your setup
there will be a tab that says regions
select region 2 that is multi region it will play regions 1-4
May 11, 2009 | Televison & Video
Unlock code to unlock dvd player to play dvds from all regions
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
make sure you have the disc draw open and enter the above code via your remote.
let me know if it works
Jan 10, 2009 | Televison & Video
PANASONIC DVD RECORDER DMR-ES35V
DVDs are region coded. This means that they will only play on a DVD player from the region the DVD was produced to be watched in. For example, an Australian DVD is Region 4. It will only play on a Region 4 player. If you try to play it on a player that is set for a different region, it will probably not play. One way around this is to get hold of a multi region player. These are widely available. Alternatively, you should be able to watch the DVD on your computer, although you may need some region free software if your computer's dvd player has been locked. Usually computer DVD players will allow you to play DVDs from any region a few times and then they will lock to a particular Region Code. If you are in North America, you will need a PAL player. The only other thing you may be able to do is to unlock your existing player to convert it to region free. Many DVD players can be unlocked but you would need to find the unlock information for your paticular player. Hope this helps....
Jul 27, 2008 | Panasonic DMR-E55 DVD Recorder
Won't play DVDs from asia .. need region code unlock.. help.
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
Apr 03, 2008 | Jwin JD-VD135 DVD Player
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Dec 19, 2007 | Televison & Video
How can I unlock my dvd player to play American dvds please?
I have a panasonic DMR-EZ45V which only plays region 2, but some dvds i want are on only on region 1, can it be changed to play both regions?
willc
Oct 26, 2007 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic DVD-S53 Logo
162 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
