Question about Zanussi ZHQ575 Electric Double Oven
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
A problem with my dishwasher element caused my RCD to trip, since then the bottom oven no longer works but the top does. is each oven protected by an internal fuse?
    President:
  • 1,462 Answers
Have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Posted on Oct 01, 2008
"TRESILLA" RANKED THE GURU GAVE ME THE SOLUTION, READING THE MANUAL AGAIN IT DOES ACTUALLY STATE THE CLOCK HAS TO BE SET HOWEVER, WHY COULD A SIMPLE SOLUTION LIKE THAT NOT HAVE BEEN MENTION BY THE ZANUSSI CALL CENTRE??? MANY THANKS TRESILLA £8 WELL SPENT!
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 | Ovens
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
Zanussi ZDQ 595 fan oven not heating
Here is a free video to help you with your cooker fan motor problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
May 14, 2010 | Zanussi ZDQ495 Electric Double Oven
Zaunssi ZBF360X built in Oven Not Heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi oven not heating
The fan element was not working, bought one on ebay replaced it works ok now. Fairly easy to fix remove inside back cover, 4 screws, you will see the element remove 3 screws pull out element pull off 2 connectors careful not to lose the wires back through the holes. replace in reverse order.
Jul 12, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZHQ575 Electric Double Oven Logo
637 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
