Question about Rowenta Professional DE880 Iron
Rowenta won't shut off automatically
I left my iron on and in upright position. I got distracted and noticed several hours later that the iron was still hot. The auto-shut off failed to work. I bought the iron at Costco so they might have their own model number.
    Scholar:
  • 62 Answers
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Posted on Oct 08, 2008
I was given a Rowenta Effective with no instruction booklet and I can't get it to work properly. When I turn it on it gets hot but soon after that bottom light goes out and the auto off light blinks
If you start ironing with it, does it come back on? It usually doesn't take long for auto-shut-off irons to turn themselves off--a few minutes in the upright postion, and about 30 seconds if left sitting in the down position. Once you start the ironing motion, it should come back on.
Oct 14, 2014 | Rowenta Effective DX1900 Iron with Auto...
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
I plug the iron in , 5 minutes later it turns off ! Is that a auto shut-off problem or something else
The iron has an auto shut off of usually 8 minutes. The iron will automatically turn on if you move the iron. If this does not answer your concern, let me know and we can look for a solution. Thanks.
Mar 15, 2011 | Rowenta Irons
My rowenta iron shuts off in the middle of ironing & spits water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 09, 2010 | Rowenta Powerglide DE011 Iron with Auto...
Auto off goes on all the time
some irons are made to shut themselves off in case they are fallen over to prevent fires try keeping it in an upright position when in use and frequently raise it up when in use
Nov 23, 2009 | Rowenta DZ1700 Iron
Shuts off when you begin ironing
If its under warrenty take it back. It may be the cable is damaged. It may be cheaper to buy a new one from wallmart or similar store.
Jul 24, 2009 | Rowenta DX6700 Iron
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Iron Problems
Rowenta has an auto shutoff feature if the iron is not used for awhile. They use multi-point security Torx head screws that require the appropriate set of bits/driver kit that may be obtained at your local Kragen's or Harbor Freight tools to access the position/timer switch mechanism. Open it carefully so you can see if the switch is somehow mechanically mispositioned or sticking. You may also want to store the iron, cool and reservoir empty in the normal upright position.
Jul 05, 2008 | Rowenta DX6700 Iron
Steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Apr 16, 2008 | Rowenta DG-980 Iron
Rowenta Professional DE880 Iron Logo
87 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
