I am tring to extend my mic distance from the radio without any luck can you help
I have a DTMF mic that hooks up to my convertacom for my mt1000. I have tried to run a cable between the mic and the radio but it just does not work
    Problem Solver:
  • 13 Answers
Thats because the interface at the convertacom is different from that of the radio -- the convertacom supplies power to the mic on the mic audio lead while the radio uses a separate wire. Get the convertacom manual and see how the mic is wired.
Posted on Nov 30, 2008
I just bought a cobra 18 wx st 40-channel base cb radio and when i talk in the mic it comes out all distorted on the other end ive tryed three different mics do you have any answeres
Well, someone could have over modulated it. Some trashy techs will cut resistors and do nothing more than make it sound icky and bleed all over. You can turn the mic gain a quarter way to the left from where you had it and see how that performs. A mic gain turned up all the way is OK for farther transitions but a mic gain turned up all the way to people much closer will sequel and sound what I call "mashed out" ( distorted. ) If this does not help then take it to a licensed tech to inspect as the fix will be from inside the radio. Also make sure your SWR is 1-1:5 and no higher than 2. You can loose distance from a high SWR and burn up your radio. Good luck.
Feb 04, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
I am trying to program my motorola mt1000 radio but I am getting a error message " SERIAL BUS ACCESS ERROR 004" I need help
This error message means that there is software/hardware problem. It can be that you have not programmed it in the right way. So, an error occurred while you were programming it. It's better to reset the unit.
Feb 14, 2010 | Motorola For MT1000 MTX800 MTX90010v...
I dont know what kind of radio i have
Hi and welcome to FixYa,
Initially, a CES- 600L is a DTMF encoder microphone with lighted keyboard. For your need:
  • almost always, the simplest requirement would be a 600 ohm mic and a PTT switch;
  • minimum of 3 wires are needed for a 2-way radio microphone to work;
  • 1-mic audio;
  • 2-PTT switch (must go to ground when PTT pressed to TX);
  • 3-common/GND;
  • in some, 4-RX audio (not needed if radio receives with no mic).
Having said the above, then any replacement microphone with appropriate microphone plug/jack could be wired to match the GE. A generic example is shown below.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 07, 2009 | GE Radio Communications
I need a manual for Motorola MT1000
You can find part manual on following link:
http://www.scribd.com/doc/8782854/MT1000-Userguide
for parts details link:
http://www.diversifiedelectronics.com/pdf/mt1000.pdf
Please post back if it makes any changes.
thank you
Dec 08, 2008 | Motorola MT1000 Compatible 2 Way Radio...
After reading programming Radio Died
Unfortunately you have a corrupted code plug. The radio will need to be serviced to clear the corruption. Or if you have a clean copy of the original programming, you can try reprogramming it. (Note: Do not use the version you had saved which led to the corruption.)
Aug 24, 2008 | Motorola For MT1000 MTX800 MTX90010v...
Programming problem
Are you using a RIB-less cable, or using a RIB (Radio Interface Box)? This error appears to have more to do with hardware than software or radio.
Aug 08, 2008 | Motorola For MT1000 MTX800 MTX90010v...
Display lock up
this happened when try to program the radio en frequencies out of band of radio?
Feb 27, 2007 | Motorola MT1000 Compatible 2 Way Radio...
213 people viewed this question
 Grubhead
Grubhead
