Question about Motorola Mobility RAZR V3
My razor won't stay on!
The battery to my razor died last night. It is fully charged now, but when I try to turn it on and press ANY button, it will turn off. I tried to get my texted messages off, but as soon as I push the "messages" button, it turns off. The same goes for every button the on phone.
    Brigadier General:
  • 7,752 Answers
Try a new battery and also take the phone and have the firmware reflash on the phone to correct this problem
Posted on Oct 05, 2008
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
My ford falcon is draining the battery with the hazards staying on
Try checking the voltage of the battery after charging and disconnecting the leads.. Batteries die if being drained too much..
Jul 19, 2014 | 1999 Ford Falcon
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My 2000 Vespa et150 won't start. Battery is fully
try jump starting as well as checking you connections
Sep 17, 2012 | Cars & Trucks
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Have 97 acura won't stay charge changed battery
the battery wont stay charged? if youre putting in a fully charged battery and your car runs, but then the battery slowly dies, the problem will be your alternator. the alternator is what maintains a car batteries charge. try replacing the alternator. hope this helps.
Aug 15, 2011 | 1997 Acura Integra Type R
Phone won't turn on at all battery was fully charged when it died
just had the same problem! hold the top sleep button and the middle button for at least 10 seconds until the apple logo comes up then try start it
Sep 24, 2009 | Apple iPhone Smartphone
Phone doesn't turn on.
You should not allow the battery to fully drain,it will die sooner.
Remove the battery for 5mins, replace,and then try and turn on the phone.
Apr 07, 2009 | Motorola Mobility RAZR V3
My motorola krzr only stays on for a few minutes after a full charge.
Yes, you should resort to a new battery, coz the old one is exhausted. Overnight charging is not a good habit. You should charge 2-3 hours until full, and remove the charger
Sep 27, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Motorola Mobility RAZR V3 Logo
91 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
