Question about Kenmore 44072 Front Load Washer
Cleaning front loader washer
I accidentally put bleach in the softner sect. to clean my washer.  Did I do any damage?
  • 943 Answers
Hi. thanks for the question . No damage is done. just pour clean water in the dispenser. thanks the appliance doc
Posted on Sep 30, 2008
Clothes aren't clean
could be a few things is it overloaded,stop useing ,softener this coats the washer and cause the pumps to get blocked up as well as the sensors,try doing a few white hot loads with bleach to clean washer as this start to remove the softener the softner also make clothes look like they have grease spots you well need to use spray and wash on these areas and let them soak,there is a product avalible on line or at ace-hardware stores its called smelly wash this product cleans the washer let it soak in wash.this may help your washer out i hope this helps.thanks
Dec 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The machine doesn't drain 100% of the water out. You can move the tub and hear the water sloshing around in the machine bottom and the moisture is now starting to form mold on the front seal
All the water does not drain. The front tub has ballance ring with water sealed in it to off set off ballance loads. The sump hose on the pumpwill also hold water. You can clean your pumps clean out trap to make sure the pump is working good. Also a drain hose higher than 6 ft off floor will cause pump not to drain all water. Front loaders all have a mold problem. no air gets in when your done washing because you close the door. If you dont use bleach and hot water washes it makes matters worse. Fabric softner is even worse.
You need to clean your washer with bleach in the front seal by hand some times.
Its the price you pay for saving water.
Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
OIl stains on clothes with front loading LG washer
ftr loader washers do not have any oil, my guess would be you are using fabric softner . that can stain clothes. dilute with water, they are very concentraded. or your dispenser may not be working properly and not releasing softner at the proper time.i would run a clean cycle through it. meaning set on a hot wash- regular cycle no clothes and run wirth bleach in bleach disenser. do this every other month to keep washer clean hope this helps. make sure its not happening in the dryer , the dryer has frt and rear seals that go bad and start leaving marks on clothes and catching them in beteween the tub.
Sep 16, 2009 | LG WM-2032H Front Load Washer
It makes my clothes smell really bad
I am not familar with this machine...but
it probably has a lint filter on the washer somewher inside the tub. Probably close to the front. also these front loaders have a big rubber seal, check and make sure nothing has fallen in between them. They make a specific product for cleaning these machines, sell it on same isle as detergent.
Jul 19, 2009 | Samsung WF337AA Front Load Washer
Help My front loading washer is not dispending
have you pulled the drawer from the machine and cleaned it thoroughly. break it down into individual pieces and clean the hell out of it. Fabric softener can build up over time and clog every crack and crevice. check also the hole the drawer goes into, water flows into the drawer mixes with f.s., bleach, etc. dilutes it and sends out the bottom.
Jun 16, 2009 | Washing Machines
Bleach compartment?
You normally use bleach to clean your washer. I have a washer nearly 15 years, never once put bleach, even for cleaning. Never cleaned it either, except dusting the exterior. I use powders for frontloaders. They seldom make these washers today, non-electronic. What they do today is make one to last about 2 years, then make you junk it & go for another - same story. Keeps their factories your time & expense. Funny is'nt it, but absolutely true.
Apr 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader ,, fab softner will not empty
your cold water may be the issue, turn off your water and check the screens to the cold water side. make sure the machine gets cold water.
Nov 02, 2008 | Kenmore Elite 45986 Front Load Washer
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 44072 Front Load Washer Logo
49 people viewed this question
Sal De
 Brian Main
Brian Main
